g686 Posted August 19, 2005 Share Posted August 19, 2005 My 240z with a 82zx turbo motor wont rev. It idles fine around 750-1000 rpm and very smooth, but it as soon as I give it any gas at all the revs fall and it almost dies, it also backfires if you hold the throttle long enough. when i let go of the throttle it idles fine. I have checked all of the electrical connections. I changed the O2 sensor I have tested the AFM and it seems to be working properly Any advice would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
bumble zee Posted August 19, 2005 Share Posted August 19, 2005 Fuel pressure? Quote Link to comment Share on other sites More sharing options...
240hoke Posted August 19, 2005 Share Posted August 19, 2005 I would double check the AFM. Sounds kinda like the problem I had with mat's car. It would start and run pretty damn good but if you gave it any gas at all it hated it but would eventually rev up with some coaxing. The afm spring had gotta off by alot (dropped perhaps i dunno). Anyway tightened it up and wah la. Also have you checked the timing? Quote Link to comment Share on other sites More sharing options...
g686 Posted August 19, 2005 Author Share Posted August 19, 2005 Is there a good way to check if the AFM is working properly? I checked it according to the haynes manual and it is working properly according to the manual. Quote Link to comment Share on other sites More sharing options...
g686 Posted August 20, 2005 Author Share Posted August 20, 2005 Theres nobody else that has any ideas im am totally out of ideas and would greatly appreciate any help at all? Quote Link to comment Share on other sites More sharing options...
g686 Posted August 20, 2005 Author Share Posted August 20, 2005 I took the j-pipe off from the turbo to the manifold, when I opened the throttle body it seemed to suck in alot of air, but as soon as it was opened more than a couple of degrees the rpms dropped and it started to ilde very rough and stumble alot? I cant tell if its not getting enough air or if its not getting enough gas? Quote Link to comment Share on other sites More sharing options...
240hoke Posted August 20, 2005 Share Posted August 20, 2005 the flapper should be pretty stiff and flip bac kas soon as you let off if it Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted August 21, 2005 Share Posted August 21, 2005 when i got tp switch wet when cleaning my motor it did that. Quote Link to comment Share on other sites More sharing options...
g686 Posted August 22, 2005 Author Share Posted August 22, 2005 I changed out the TPS with a working one from another car and it didn't solve the problem at all. I think it could be running lean because when I squirted gas into the AFM with a squirt boddle it reved up good? So I was wondering what could cause that lack of gas? I made the AFM almost as rich as it could go and it didn't make a difference? I am at a total loss right now? Quote Link to comment Share on other sites More sharing options...
akeizm Posted August 22, 2005 Share Posted August 22, 2005 bumble zee said: Fuel pressure? As he said, have you checked that? Quote Link to comment Share on other sites More sharing options...
g686 Posted August 22, 2005 Author Share Posted August 22, 2005 ya the fuel pressure is at 30 psi at idle and it goes up when i push the throttle. Quote Link to comment Share on other sites More sharing options...
Thumper Posted August 22, 2005 Share Posted August 22, 2005 Its either your afm or you have a leak in your intake piping some where. Check all hoses, bov, egr, aac, both nipples on turbo, and etc... Quote Link to comment Share on other sites More sharing options...
