240Z_Master Posted September 5, 2005 Share Posted September 5, 2005 Specific Question... Did Nissan change the R180 design in 280Z's after 8/76. Basically if Nissan changed the R180's to circlups in the later 280Z's, could you take those clip in stubs and adapt them to the R180 out of the 200SX, then bolt the stock 240Z half shafts? If not then I will have to find the 1st Gen Maximas and grab the CV + Companion Flanges. Quote Link to comment Share on other sites More sharing options...
260DET Posted September 5, 2005 Share Posted September 5, 2005 Can't answer your query directly, but on a short nose R180 diff I had the clip in stub axles were slightly larger in diameter than those of an earlier long nose R180. The short nose stubs fitted a Subaru R180 LSD. Quote Link to comment Share on other sites More sharing options...
johnc Posted September 5, 2005 Share Posted September 5, 2005 The diff side stubs are basically interchangeable although the through-bolt type won't have a physical attachment to the diff. I've swapped back and forth at the race track when I've forgotten the proper spares. BTW... with the longer wheel travel involved, I wouldnt run the through-bolt stubs in a circlip R180 on a street car. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted September 5, 2005 Author Share Posted September 5, 2005 The diff side stubs are basically interchangeable although the through-bolt type won't have a physical attachment to the diff. I've swapped back and forth at the race track when I've forgotten the proper spares. BTW... with the longer wheel travel involved, I wouldnt run the through-bolt stubs in a circlip R180 on a street car. Thanks for that John... helpful info. I went to the local Pick a Part and grabbed a set of 1st gen Maxima CV's and the entire lower control arm, maybe this will work with my "K" Box R180. Quote Link to comment Share on other sites More sharing options...
