boost and mechanical fuel pump?......
FEnatic
OK, I tried the search for awhile and found some interesting stuff, but, to use a mechanical fuel pump in a boost situation you need to raise the pressure. Is this a matter of using a high pressure mechanical pump with a boost sensing, rising rate regulator, or I've heard that a mechanical pump can be modified to increase pressure depending on boost? Where can I find out about this, I've googled for awhile too but not many definite answwers. I want to twin turbo a V8 Ford I've got, but keep the carbs on. I know about the carb mods too. Any help here is appreciated. Thanks
  • 1 year later...
Guest jds6175
Check out this website racepumps.com, they have a mechanical pump that will flow some numbers for about$ 399. You can also run an aeromotive A1000 pump which I think can handle around a 1000 hp. I plan on running the aeromotive with a boost sensetive regulator on my 351w, carb'd , with a supercharger. The aeromotive is an electric pump that requires you to run a return line to the tank off the regulator whereas the one from race pumps doesn't require it and can handle up to 2000 hp i beleive. The good thing about the mechanical pump is the rebuild kit for it is only $10! Hard to beleive! Good luck!
By the way, where did you find out about the carb mods? If you can, would you mind sending me the link? My email address is flyboy262626@yahoo.com . Thanks!
Ohhhhh, young-uns here, eh? LOL
To get the rising fuel pressure from a mechanical pump, you tap the 'spring side' of the diaphragm housing, and supply boost pressure. Your resultant fuel pressure will rise as boost does, and keep original fuel pressure biased by the original fuel pump pressure plus boost.
