Superz Posted September 16, 2005 Share Posted September 16, 2005 I have an R200 4.11 LSD in my 240z. I purchased this diff from Arizona Zcar about 8 years ago. He told me it was from a Skyline, which one I dont know. ANyhow, I need to replace the carrier and pinion bearings but I have no clue as to how to order a set. Do all R200s share the same bearings? Any advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 16, 2005 Share Posted September 16, 2005 The R200's do not share all the same bearings. My 300ZXT diff had a different inner pinion bearing than my 86 200SXT diff. I think everything else was the same IIRC. If you knew what car it came from you might be able to call Nissan and figure it out. I think AZC got all of their diffs from R32 Skylines, not absolutely sure on that though. Quote Link to comment Share on other sites More sharing options...
Clifton Posted September 18, 2005 Share Posted September 18, 2005 It's from an R31. R32+ use the short nose R200. There should be numbers stamped on the bearing somewere. If you can get those, getting bearings shouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
