Z48LT-1 Posted November 7, 2006 Share Posted November 7, 2006 You guys are crazy. But in a good way! Cheers -- Gary Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted November 8, 2006 Share Posted November 8, 2006 just some info your looking to spend $6000-$8000 plus on an engine here, thats getting into BIG BLOCK territory now all im suggesting here is step back and think thru your options, while having a 500hp-600HP sbc may be a good idea,BUT ITS CLOSE TO MAX, having a 600hp-700HP plus big block for a similar OR SLIGHTLY HIGHER cost with alot MORE GROWTH POTENTIAL IN THE FUTURE HAS ITS GOOD POINTS http://www.greenwoodchevy.com/engine17.htm http://www.sdpc2000.com/catalog/120/products/689/ZZ502-Base-Kit-Fully-Assembled-GM-Performance-Parts-Crate-Engine.htm http://www.theengineshop.com/prods_pages/108000.htm http://www.theengineshop.com/prods_pages/108061.htm YOU DON,T NEED TO GET CRAZY EITHER read this below http://maliburacing.com/patrick_budd_article.htm Quote Link to comment Share on other sites More sharing options...
gvincent Posted November 8, 2006 Share Posted November 8, 2006 There asking $2000 for that 406, going on the grocery list of parts in the ad do you think it is a good deal? What questions should I ask besides to see receipts for everything? Cam specs? Quote Link to comment Share on other sites More sharing options...
Pyro Posted November 10, 2006 Share Posted November 10, 2006 If you are going to build a stroker sbc, plan on getting the rotating assembly internally balanced so you can run the smaller 6 inch balancer and 153 tooth flywheel to clear the Z's engine compartment. Quote Link to comment Share on other sites More sharing options...
gvincent Posted November 11, 2006 Share Posted November 11, 2006 SO internal balancing is a must? I thought there were smaller fluid balancers that I could use? Quote Link to comment Share on other sites More sharing options...
Pyro Posted November 13, 2006 Share Posted November 13, 2006 I think I have seen a smaller externally balanced damper but I haven't seen a 153 tooth, externally balanced flywheel or flexplate. Quote Link to comment Share on other sites More sharing options...
