Guest 73Turbo240z Posted October 7, 2005 Share Posted October 7, 2005 I'm going to run all new sensors on the engine, so i figure i'll pick up the recommended GM ones, only snag i can see is the thread might not be the same as the block. So here i am asking... for those that run the GM sensors on your engine, did they thread right up? Where did you install yours? And if they didn't thread up, how did you go about securing them? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted October 7, 2005 Share Posted October 7, 2005 Don't know if they are the same but I do know that the GM sensors (coolant and IAT) are 3/8" NPT thread size. Now, does someone know what the thread size is for the nissan block? Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted October 7, 2005 Share Posted October 7, 2005 mobythevan said: Don't know if they are the same but I do know that the GM sensors (coolant and IAT) are 3/8" NPT thread size. Now, does someone know what the thread size is for the nissan block? got one piece of the puzzle now... next portion of the puzzle though, where are the choice places to put these sensors, obviously w/ the IAT sensor somewhere in the vacinity of the throttle body, probally a few inches before it. for the coolant though, i've heard mixed opinions, in the cyl head, which wouldn't be in coolant at all? or use one of the taps right off the thermostat housing? Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted October 8, 2005 Share Posted October 8, 2005 the bottem half of the thermostat housing has a spot you can drill and tap for 3/8 pipe thread.that was on my 81zxt motor.the 83 zxt motor had a plug you could remove and install gm coolant sensor.pipe taps are easy to get -try osh or lowes.use thread cutting oil on the tap.since i am computor challenged i chose not to try to use easytherm program and nissan sensor.the air sensor is easy.if you want it behind the throttle blade you could tap the cold start injector hole on a na intake manifold.i am not squeemish about modifying parts. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted October 10, 2005 Share Posted October 10, 2005 so what about tps is anybody running the stock Z tps with megasquirt? or is the 240sx a pentometer type ( I think i read that somewhere?) -Ed Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted October 10, 2005 Share Posted October 10, 2005 Quote so what about tps is anybody running the stock Z tps with megasquirt? or is the 240sx a pentometer type ( I think i read that somewhere?) -Ed 240sx TPS for me... though i notices last night that my TPS differs from the ones Mike and Ted have.. theres have plugs on the module... mine has a pigtale out of the module to a plug socket... so i'm a tad concearned that i might have the wrong TPS sensor. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted October 11, 2005 Share Posted October 11, 2005 Why not use EasyTherm and the stock sensors? Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted October 11, 2005 Share Posted October 11, 2005 Brad-ManQ45 said: Why not use EasyTherm and the stock sensors? cause i'm running all new sensors... and i figured keep it simple, keep to the MSnS initial setup criteria. Quote Link to comment Share on other sites More sharing options...
240hoke Posted October 11, 2005 Share Posted October 11, 2005 Im running my temp sensor in the head, it screwed right in. The knock sensor I had to retap the block for. Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted October 11, 2005 Share Posted October 11, 2005 240hoke said: Im running my temp sensor in the head, it screwed right in. The knock sensor I had to retap the block for. your running a CHT... i wont' have a knock sensor in my MSnS setup... i'm going to tune w/ street pulls in 2nd and/or 3rd and a LM1 wideband. Datalog it and try to plot out a safe 12.5:1 ratio across the powerband. Quote Link to comment Share on other sites More sharing options...
evildky Posted October 12, 2005 Share Posted October 12, 2005 the stock tps is only a switch and will nto work with the MS, I added a tab to a 240sx so I coulsd use it with my stock tb till I upgraded my tb Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted October 12, 2005 Share Posted October 12, 2005 evildky said: the stock tps is only a switch and will nto work with the MS, I added a tab to a 240sx so I coulsd use it with my stock tb till I upgraded my tb i'm using a 240sx tb... Quote Link to comment Share on other sites More sharing options...
