bob88 Posted October 8, 2005 Share Posted October 8, 2005 Im almost done with my swap I got the drivshaft back yesterday with the JTR flange on the back of it. I put the drivsaft in and the holes didnt line up on the differential flange to the JTR flange. What can i do to make the flanges fit? Quote Link to comment Share on other sites More sharing options...
DavyZ Posted October 8, 2005 Share Posted October 8, 2005 Im almost done with my swap I got the drivshaft back yesterday with the JTR flange on the back of it. I put the drivsaft in and the holes didnt line up on the differential flange to the JTR flange. What can i do to make the flanges fit? http://forums.hybridz.org/showthread.php?t=82276&highlight=differential+flange Got this by doing a search using your thread title. I'm sure there are more here if you search for them... Davy Quote Link to comment Share on other sites More sharing options...
bob88 Posted October 8, 2005 Author Share Posted October 8, 2005 Alright, thank you. I figured out that my 75 Z has a 2" differential flange not the 2.25" in every other model What a pain Anybody have a 2.25 flange? Guess im going to the junkyard instead of paintballing tomarrow. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted October 9, 2005 Share Posted October 9, 2005 I had the same problem(thats what that link that Davy posted is about). I dont know if a junk yard will sell just that flange since with out it the diff is useless. I think it cost me $30 to have mine modified so that it would fit. Just take the adapter and the diff flange to a machine shop and tell them to make it fit and they will. Its not a big deal for them since they have the machines to do it. Guy Quote Link to comment Share on other sites More sharing options...
DavyZ Posted October 9, 2005 Share Posted October 9, 2005 I had the same problem(thats what that link that Davy posted is about). I dont know if a junk yard will sell just that flange since with out it the diff is useless. I think it cost me $30 to have mine modified so that it would fit. Just take the adapter and the diff flange to a machine shop and tell them to make it fit and they will. Its not a big deal for them since they have the machines to do it. Good advice from Guy---this is the absolute simplest way to do it if you don't have the opportunity to pick and choose your parts along the way. $30-$50 is paltry compared to the total cost of the swap. Just my $.02 Good luck. Davy Quote Link to comment Share on other sites More sharing options...
getZ Posted October 9, 2005 Share Posted October 9, 2005 That's funny, I have the oppsosite problem. Orginally I had a r200 with a 2.25 inch flange. I had to get a later model diff with 12mm ring gear bolts and it now has a 2.0 inch flange. PM me and we can do a swap. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted October 9, 2005 Share Posted October 9, 2005 When I swapped an R200 into my 240 I originally got the wrong diff flange. the JY had no problem letting me swap the wrong diff flange for the correct one. If this is the only problem you encounter you have done well. Quote Link to comment Share on other sites More sharing options...
MikeJTR Posted October 9, 2005 Share Posted October 9, 2005 JTR now carries three different driveshaft flanges to fit three different Z differentials. 2 with the 2 inch pilot, and one with the 2.25" pilot. They aren't yet mentioned on the website, but if you purchased the wrong part for your vehicle, call Greg at JTR on the week day, and he will take care of it. Quote Link to comment Share on other sites More sharing options...
bob88 Posted October 10, 2005 Author Share Posted October 10, 2005 O I've encountered problems, just read the book and used the search bar like you guys say too. It really gets frustrating when nothing works the first time. I'll PM getz, but if that doesnt work ill ask a machine shop to do it Thanks for all your help BTW Quote Link to comment Share on other sites More sharing options...
azguy Posted October 10, 2005 Share Posted October 10, 2005 I kinda had a different problem. The pilot size was right but the bolt holes didn't quite line up right. I had a machine shop fix it no problem. Same shop that cut and balanced my driveshaft fixed it with no extra charge. Gotta love those machine shops. Quote Link to comment Share on other sites More sharing options...
getZ Posted October 10, 2005 Share Posted October 10, 2005 I didn't realize there were different bolt patterns for different r200's. AZguy, which type flange did you have on your r200, round or square? Quote Link to comment Share on other sites More sharing options...
bob88 Posted October 11, 2005 Author Share Posted October 11, 2005 mines square. I went out to pull the nut off that holds the flange on and it wont budge I tried everything I used WD-40 tapped it with a hammer and put a wrench on the socket handle it just twists the mount. Any suggestions Quote Link to comment Share on other sites More sharing options...
Tim240z Posted October 11, 2005 Share Posted October 11, 2005 Big @$$ impact wrench and socket and about 125psi of air...... Quote Link to comment Share on other sites More sharing options...
80LS1T Posted October 11, 2005 Share Posted October 11, 2005 Big @$$ impact wrench and socket and about 125psi of air...... If that doesnt work or you dont have one.......... Put 2 long bolts into the diff flange bolt holes across from each other. Then put a pipe in between those bolts. Then put the biggest and longest breaker bar you have (and a pipe on the breaker bar if you have one) and you should be able to bust that nut loose. Before you take it off though you'll want to stake both the nut and the pinion(that the threaded part that the nut goes on), so that you know now far to tighten it back down when you put it back together. Guy Quote Link to comment Share on other sites More sharing options...
bob88 Posted October 11, 2005 Author Share Posted October 11, 2005 Alright, now after that workout i got it off the flange still doesnt pull out. I have the chiltons manual, its unclear how to get it out. Does anybody have any experience pulling it out I thought it would pill out similar to the yolk in a transmission after the nut was gone Quote Link to comment Share on other sites More sharing options...
80LS1T Posted October 11, 2005 Share Posted October 11, 2005 Just tap on it with a hammer, it will come off. Theres nothing else holding it on. Guy Quote Link to comment Share on other sites More sharing options...
bob88 Posted October 11, 2005 Author Share Posted October 11, 2005 Alright thanks, i couldnt get it off with just pulling it off so i used a puller (makes sense right ) and got it off. Quote Link to comment Share on other sites More sharing options...
