Alf Posted October 15, 2005 Share Posted October 15, 2005 I had my stock 305 running great and now it wants to die when it gets hot, it barely wants to run, any ideas? Quote Link to comment Share on other sites More sharing options...
Guest traub83 Posted October 15, 2005 Share Posted October 15, 2005 hmm, carb calibration maybe??? Does your engine overheat or anything? what you said was pretty vauge to flat out give a good guess.. Quote Link to comment Share on other sites More sharing options...
Alf Posted October 15, 2005 Author Share Posted October 15, 2005 If I drive it when it is cold it runs good but once it gets hot it sputters and just quits. The timing is set at 30 degrees and the carb is a stock 600cfm holley spreadbore, and i just put a rebuilt distributor in it. Would it die if it got hot? Quote Link to comment Share on other sites More sharing options...
Guest traub83 Posted October 15, 2005 Share Posted October 15, 2005 well the timing is what I was about to say next.. Umm well if it gets too hot yes it could die however unlikely but I have seen it before... It sounds to me honestly that when it is getting warm your not getting spark... Id check out your coil cause when it gets warmer it could be goin haywire but when its cool it works fine.. Id basically start to really take a close look at your ignition items, plugs, coil, wires, distriburor, ignition box, exe.... also maybe check your muffler bearings when they go out all hell breaks loose heh heh heh Quote Link to comment Share on other sites More sharing options...
Alf Posted October 15, 2005 Author Share Posted October 15, 2005 It may be the coil cause its pretty old, what happens exactly. The plugs havn't even been in a week, new cap, rotor, dwell set at 30. I'm stumped. I think i need to get a different fan temp switch so it stays a little cooler, it seems like there is very little airflow through the engine compartment. Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted October 15, 2005 Share Posted October 15, 2005 ignition module Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted October 15, 2005 Share Posted October 15, 2005 I think Tony has it right, ignition module. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted October 15, 2005 Share Posted October 15, 2005 Second thought, kind of humorous. "MAYBE IT'S DYING TO BECOME A 406!" Ha ha!!!!!!!! Quote Link to comment Share on other sites More sharing options...
skipzoomie Posted October 15, 2005 Share Posted October 15, 2005 The guys have it right. But you might check for vapor lock also. Not much airflow is a clue to higher than normal under hood temps. If you have points and cond. ignition then there is no ignition module. I've never had a module die slowly. They usually just quit. On the other hand old coils will give sporatic performance. Quote Link to comment Share on other sites More sharing options...
Alf Posted October 15, 2005 Author Share Posted October 15, 2005 It has points, no ignition module. could a cheap set of points do this? I'm almost positive its not vapor lock either cause i have all the fuel lines and regulator wrapped in heat reflective material. Quote Link to comment Share on other sites More sharing options...
Guest traub83 Posted October 15, 2005 Share Posted October 15, 2005 yes cheap points could do it or unset ones.. But I hav my money on the muffler bearings or possible the blinker fluid when those go out whoo hoo thats some trouble lol.... Quote Link to comment Share on other sites More sharing options...
Alf Posted October 15, 2005 Author Share Posted October 15, 2005 Well i have another set of mallory performance points, I can throw in there and see what happens. I noticed the other points are floating when it reaches the upper rpm range, and the condensor burnt out on me 2 days after i got it so i dont think the points of are any quality either. Quote Link to comment Share on other sites More sharing options...
Guest traub83 Posted October 15, 2005 Share Posted October 15, 2005 id throw them on and see what happens i bet it solves the problem... Quote Link to comment Share on other sites More sharing options...
Alf Posted October 15, 2005 Author Share Posted October 15, 2005 Yeah im gonna try it out, ill let you all know what happens. Quote Link to comment Share on other sites More sharing options...
Alf Posted October 15, 2005 Author Share Posted October 15, 2005 I changed the points, coil, and power-valve and it still does the same thing. Quote Link to comment Share on other sites More sharing options...
Alf Posted October 18, 2005 Author Share Posted October 18, 2005 I also ajdusted the timing slightly, adjusted the fuel pressure to 5psi, and adjusted the idle mixture screws, its pulling 19 inches of mercury, i also have my electric fan running non stop, and i put a 1/4 inch gasket/spacer under my carb for heat isolation and it still dies out. i'm running out of ideas. Quote Link to comment Share on other sites More sharing options...
mark Posted October 19, 2005 Share Posted October 19, 2005 How long does it run before it gets hot? A few minutes? Could it be a clogged fuel filter. Car would run OK for a few minutes until the bowl empties and the reduced fuel flow shows up. Quote Link to comment Share on other sites More sharing options...
Alf Posted October 19, 2005 Author Share Posted October 19, 2005 It will run for about 15 min, and the fuel filter looks clean but i should take it off and check. Quote Link to comment Share on other sites More sharing options...
buZy Posted October 21, 2005 Share Posted October 21, 2005 Vapor Lock? Are all your fuel lines away from hot exhaust pipes etc? Maybe 15 mins is too early for this condition but anything is possible. Quote Link to comment Share on other sites More sharing options...
Alf Posted October 21, 2005 Author Share Posted October 21, 2005 i have all the fuel lines wrapped in heat reflective sheathing and a 1/4 inch heat spacer/gasket under the carb Quote Link to comment Share on other sites More sharing options...
