Jersey Posted October 19, 2005 Share Posted October 19, 2005 Hey all. Question: Does the outer cv flange bolt configuration on the '87-'89 300ZXT halfshafts line up with any of the 240, 280 or 280zxt stub axle companion flanges? My cousin just picked up an '87LSD that's coming with the halfshafts and would like to use them instead of the 280zxt halfshafts that he's runing now. I do know that ross sells adapters but was just wondering if they were 100% necessary to do this swap. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 19, 2005 Share Posted October 19, 2005 The 300ZXT flange is a 4 bolt. The 280ZXT flange is a 6 bolt IIRC. Also the 300ZXT CV is longer, so the adapter has to be thinner to work. Quote Link to comment Share on other sites More sharing options...
Jersey Posted October 19, 2005 Author Share Posted October 19, 2005 Thanks Jon and thanks for reminding me that the 280zxt stub axle flange i used was 6 bolt. Been a while since i've done the swap! I just got a look at the 300ZXT halfshafts and that outer bolt pattern won't match up with either the 240/260/280 stub flange. It's much bigger and looks like the adapter is needed to use these halfshafts. For the length of them, here's a blurb from Ross's site: 300ZXT 4 bolt outerflange CV shafts (not the 6 bolt type) require the end cap removed, and inner CV race reversed, this effectively shortens each CV shaft 3/8" and results in correct rear geometry for your Z So the length doesn't look to be a problem, just need the adapter i guess. Think i'll just use the 280zxt halfshfts for now to get it up and running. Thanks again. Quote Link to comment Share on other sites More sharing options...
BrandonsZ Posted October 19, 2005 Share Posted October 19, 2005 I heard you take the flange off the stock 240 halfs and press in the u-joints from the 300. then you don't need an adapter. Woudl this work? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 19, 2005 Share Posted October 19, 2005 That don't make no sense. CV's don't have U-joints. Quote Link to comment Share on other sites More sharing options...
BrandonsZ Posted October 19, 2005 Share Posted October 19, 2005 Oh CV style, LA-DE-DA Quote Link to comment Share on other sites More sharing options...
Jersey Posted October 23, 2005 Author Share Posted October 23, 2005 Do the Z31's have stub axle flanges like our Z's? If so, do they mate with either the 240 or 280 stubs and/or, can we use the entire Z31 stubs/flanges/cv halfshaft combo? Thanks. Quote Link to comment Share on other sites More sharing options...
RedZ85 Posted October 25, 2005 Share Posted October 25, 2005 Do the Z31's have stub axle flanges like our Z's? If so, do they mate with either the 240 or 280 stubs and/or, can we use the entire Z31 stubs/flanges/cv halfshaft combo? Thanks. ZX stubs are a different shape than the Z stubs. They use different bearings and would require machining of the strut housing to fit. Not a path that you want to take. The best and cheapest way to do it is get the stub axles from a 280Z (27 spline count, or for $700 you can get Ross' stubs in any hub pattern you want...but thats more $$) and get Ross' adapters. Then flip the race in the CV shaft to shorten it and bolt it in. I have this setup and its fantastic! Quote Link to comment Share on other sites More sharing options...
Jersey Posted October 25, 2005 Author Share Posted October 25, 2005 Thanks Red. Quote Link to comment Share on other sites More sharing options...
