Guest PROJECTRB240SX Posted October 20, 2005 Share Posted October 20, 2005 I Was Going To Order Some Qa-1 Coils For My Coilover Set And Was Looking For 8" Coil Lengths In 150/200 Setup (sr20 240z). Well They Don't Have Anything Lower Than 200lb Springs In 8". Would It Be Okay To Run A 10" 150 Front Spring With A 200lb 8" Rear Spring? I'm Honestly Dumb When It Comes To Suspension Peices And I've Searched For The Past Week For This Answer... But All The Results Don't Really Cover This Question (unless My Search Words Are Not Right). Thanks For Any And All Help, Christian Quote Link to comment Share on other sites More sharing options...
mark Posted October 20, 2005 Share Posted October 20, 2005 Different length springs front to rear will be OK. I've got my lt-1 240 set up with 8 inch rear and 10 inch front springs. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted October 20, 2005 Share Posted October 20, 2005 Ok.... Some More Questions: Do I Have To Compensate With A Lower Coilover Sleeve Location For The Longer Springs? Will Tokico Hp Cartridges Work With 150/200 Spring Rates Or Do I Have To Step Up To Illuminas? I Was Given A Set Of Hp Struts (hz3099 Front, Hz3013 Rear) So I Can Assemble My Coilovers (still Waiting For My Illuminas) And Was Debating On Cancelling My Illumina Order If These Hp Struts Will Work For Spirited Road Driving/open Road Racing. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted October 21, 2005 Share Posted October 21, 2005 A longer spring will require the seat to be lower providing all other things are equal (ride height, corner weight, spring rate, etc). The HP should be fine with these rates, but I wouldn't go any higher than the 200 you've commited to use. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted October 21, 2005 Share Posted October 21, 2005 Well Its More Of A Street/weekend Warrior So More Than 200lb Springs Would Be Too Harsh. I Plan On Having A Slight Front Rake But Other Than That I Hope To Make Everything Else Equal (3-3.5" From Ground To Frame Rail). Thanks For The Help And Information Everyone, I Really Appreciate It. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 21, 2005 Share Posted October 21, 2005 Read this thread on why you SHOULDN'T get a 200 lb 8 spring on a Z... http://forums.hybridz.org/showthread.php?t=102442 Maybe you could get some extra long bumpstops? Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted October 21, 2005 Share Posted October 21, 2005 So Would It Be Better To Go With 10" Springs Front And Rear? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 21, 2005 Share Posted October 21, 2005 Yes, because an 8" spring will coil bind before the strut runs out of travel. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted October 21, 2005 Share Posted October 21, 2005 Even With Ross' Hyperco Springs? Thanks Jon For The Helpful Information! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 21, 2005 Share Posted October 21, 2005 Yes I am 99.9999% that the Hyperco will have the same problem everyone else has. Spring rate is based on the size of the wire and the number of coils, and you don't have too much room to play around when you already have the ID and length set. Check with Ross to for the extra .0001%. Quote Link to comment Share on other sites More sharing options...
