Guest Arizona-ZMAN Posted October 27, 2005 Share Posted October 27, 2005 I have a constant starting problem with one of my 75 280Z's. Any time I put the key in the ignition and turn the key to start... all I hear are relays clicking. This happens several times... usually 7 or 8 or more. About the time I give up, it starts up and runs fine... until I turn it off and attempt to start it again... then the same process again... click, click, click, click, click, click... I have already replaced the starter, battery and ignition switch... I suspect a faulty ground or fusible link... but I have no idea how to proceed for troubleshooting the problem. Please help... I need some ideas on how to proceed and where to look first, second and third and .... Arizona-ZMAN Quote Link to comment Share on other sites More sharing options...
VRJoe Posted October 28, 2005 Share Posted October 28, 2005 Could be a bad ignition switch. Try using a remote starter button. Turn on the key then kit the button, if it starts you know it the switch. - Joe Quote Link to comment Share on other sites More sharing options...
Phantom Posted October 28, 2005 Share Posted October 28, 2005 If the car is basically stock it is time to get a factory service manual. Quote Link to comment Share on other sites More sharing options...
Guest Arizona-ZMAN Posted October 28, 2005 Share Posted October 28, 2005 Thanks Joe... but I have already replaced the starter, battery and ignition switch and still have the same problem... Quote Link to comment Share on other sites More sharing options...
280zNHChris Posted October 28, 2005 Share Posted October 28, 2005 Sounds like you have a bad connection somewhere. Not enough power to one realy , so it isn't switching fully. Like the old Ford starter relays, if the power is not strong enough, it won't pull the washer to make the connection. I'd trace the wires and check around the relay's. Chris Quote Link to comment Share on other sites More sharing options...
EZ-E Posted October 28, 2005 Share Posted October 28, 2005 Ive been there with my 280ZX, the same problem, I have replaced wireing, relays, and all fusible links but still havent found the problem. I have checked the ignition switch and it was good according to the FSM, that is also how I did the wiring for what was involved. Im still at a loss as this only happens when it is cold or very damp outside, during the summer months, I havent a problem with this at all, starts up everytime all the time. I wish you luck in your search as it might also assist me. I hope you can track this gremlin down as I have been trying to for the past 2 years. Quote Link to comment Share on other sites More sharing options...
innerware Posted October 28, 2005 Share Posted October 28, 2005 I am going to second the connection idea. There has got to be a bad or corroded conenction somewhere. As mentioned go throught the system cleaning and double checking all electrical connections. Quote Link to comment Share on other sites More sharing options...
Phantom Posted October 28, 2005 Share Posted October 28, 2005 Battery cables have a tendancy to corrode internally over the years. You might put an ohmeter on them and see what kind of resistance they have. That clickety sound is symptomatic of not enough juice to pull the solenoid in and engage the flywheel. Sometimes when you think you've checked/replaced everything it's time to check them all again. I've known cases, for instance, of new batteries that were defective - or starters for that matter. Quote Link to comment Share on other sites More sharing options...
Phyxius Posted October 28, 2005 Share Posted October 28, 2005 I have that problem when my starter goes out (about once every 3-4 months). A new starter usually fixes the problem, but since you've already replaced yours, I'm not sure what to tell you. Quote Link to comment Share on other sites More sharing options...
Thumper Posted October 28, 2005 Share Posted October 28, 2005 I would put a 12v power on the starter solenoid and see if it turns. If it doesn't then you know its the starter. If it does then you know its your wiring. Then check the wire that goes to the starter solenoid and see what voltage it puts out when the key is in the start position. And work your way back to the ignition switch from there. Quote Link to comment Share on other sites More sharing options...
dj paul Posted November 15, 2005 Share Posted November 15, 2005 definately break out the multimeter. you can put the neg on a ground, and test the voltage on each of the suspects, that way you can find shorts in your wires. Quote Link to comment Share on other sites More sharing options...
2126 Posted November 15, 2005 Share Posted November 15, 2005 Always check the simple things first.....like the ground connection to the chassis from the battery. The symtem you describe leads me to think you just have a bad/corroded ground at the chassis. Worth looking at anyway! Quote Link to comment Share on other sites More sharing options...
