Jwink25 Posted December 8, 2005 Share Posted December 8, 2005 I need a new turbo for my zcar and found what I think is a good deal on a turbo. It is a GT-40. I plan on making 400ish HP. I will be using a custom intake and a 60mm to maybe a 65mm TB. Also, plans are for a mild turbo cam. I'll be running MS as well and injectors that can handle 400ish HP. So...is the GT-40 overkill? Anyone running one of these? Any thoughts on this? Thanks! Jason Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 8, 2005 Share Posted December 8, 2005 Depends on the turbine A/R housing. But for 400WHP, GT35R with 82mm 56trim would be a better choice. I have GT37 for sale which is little smaller than GT35R. Quote Link to comment Share on other sites More sharing options...
Jwink25 Posted December 8, 2005 Author Share Posted December 8, 2005 what are you asking for it? Quote Link to comment Share on other sites More sharing options...
1FASTKINGCAB Posted December 8, 2005 Share Posted December 8, 2005 I'll go out on a limb and say YES that GT-40 is to big for the street The GT35 is a Far better choice. you could pull 500hp out of a GT35 at that Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 8, 2005 Share Posted December 8, 2005 what are you asking for it? it's listed on the classfield. A/R is little bit for I-6 though. Quote Link to comment Share on other sites More sharing options...
violacleff Posted December 9, 2005 Share Posted December 9, 2005 Big difference in price between a GT40 and a GT35R, about $700 difference. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 9, 2005 Share Posted December 9, 2005 You can get PTE SC61 if you don't mind some surge and non BB CHRA. Same compressor wheel as GT35R (gt40 wheel) with stage V turbine OR they have a new one out SC3561? (I think) which has anti surge cover. Quote Link to comment Share on other sites More sharing options...
violacleff Posted December 10, 2005 Share Posted December 10, 2005 I don't get what you mean by the surge. What is the cause of this? Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 10, 2005 Share Posted December 10, 2005 That happends when your turbo is making more airflow than what the engine can take in. Sort of like backed up drain. Quote Link to comment Share on other sites More sharing options...
violacleff Posted December 10, 2005 Share Posted December 10, 2005 Hmm, so does that have to do with an improperly sized turbo? I'm guessing this will kill the turbo over time. The GT35 isn't that large a turbo though. I guess I don't understand what would cause the surge in this particular turbo as opposed to others, particularly larger ones Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 10, 2005 Share Posted December 10, 2005 gt35 and gt35R is different. GT35R is pretty big. it's 61mm inducer. Moostly improper size(too small) turbine housing or oversize compresor will cause this. Or inefficient engine rpm like 5th gear 3000rpm going up hill where load is high but VE is low. Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 11, 2005 Share Posted December 11, 2005 Surge is the reversal of flow through a dynamic compressor, done when the minimum flow for the pressure the unit is operating at is exceeded. It can snap off blades, hammer bearings into dust, and generally ruin a day really quickly. When it happens severely and repeatedly in large industrial compressors, you get on the horn while it's coasting down after the vibration shutdown. All you can do is listen while you hear the parts rattling around tearing each other up until it finally stops. This can be the longest set of minutes in your life if you're the startup engineer and everybody wants to know what went wrong... LOL Quote Link to comment Share on other sites More sharing options...
