finally got me a cam...
... for my 460 (454 + 0.030"). It's a "low lash" mechanical roller from Cam Motion. Cam card says: (all duration numbers at 0.050", angles are in crank degrees, unless otherwise specified)
Lobe sep 112.2 (cam deg)
overlap 21.6
ground +4 advanced
Intake:
open 12.5 BTDC
centerline 108.2 ATDC
closed 48 ABDC
duration 240.5
lift 0.64178
lobe area 30.19 inches * degrees
Exhaust:
open 62.3 BBDC
centerline 116.2 BTDC
closed 9.1 ATDC
duration 251.4
lift 0.64553
lobe area 32.29 inches * degrees
The open/closed/overlap numbers look a little funny only because these are quoted at 0.050", instead of the more common at 0.006" or 0.020". The large disparity between intake and exhaust duration is because of the heads: Brodix Race-Rite oval port heads, which flow great on the intake side, but e/h ration ain't so hot. And the exhaust tract in general is pretty restrictive (small-tube headers, 2 1/4 pipes).
So, the cam goes in next month. Then clearance checks, then pushrod measurement, then.... well, let's not get too carried away here. But I did promise myself to get this car running in 2006!
Two things...
Ditch your existing exhaust. After spending all that cash on the motor, you gotta get it breathing...
Get that low (below 1000RPM) power band dream out of your head. That car should be in the 10s when done, but it won't get there shifting below 2K rpms! :lmao:
Mike :cool:
