Guest gbvol54 Posted January 21, 2006 Share Posted January 21, 2006 What am I overlooking? I've seen lots of posts regarding what master cylinder to use with a hydraulic clutch setup. Many say the 82-92 camaro/firebird slave will work but most suggest a tilton master cylinder (as does the JTR manual). I've seen none that suggest using the matching chevy master cylinder. Is it a physical fit issue? Quote Link to comment Share on other sites More sharing options...
DaleMX Posted January 21, 2006 Share Posted January 21, 2006 For me it was. The Tilton and Willwood cylinders are a real close match to the Datsun cylinder. All you have to do is widen the hole in the firewall a bit, and replace the Tilton plunger and boot with the old Datsun one. Real easy conversion and it looks stock. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted January 21, 2006 Share Posted January 21, 2006 Also, The chevy Master is made to mount at an angle that will not naturally align to the Datsun firewall. Simply put, the Tilton/ Wilwood units are the best Factory style install. Can't beat them. Mike Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted January 21, 2006 Share Posted January 21, 2006 Try doing a search in all honesty, there is tons of info. Good luck! Quote Link to comment Share on other sites More sharing options...
Guest gbvol54 Posted January 22, 2006 Share Posted January 22, 2006 Thanks for the responses. I did try numerous searches and found lots of info on the Tilton and Wildwood. What I wanted to know was why the Chevy MC wasn't used. Thanks to Dale and Mike I now know. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted January 22, 2006 Share Posted January 22, 2006 Thanks for the responses. I did try numerous searches and found lots of info on the Tilton and Wildwood. What I wanted to know was why the Chevy MC wasn't used. Thanks to Dale and Mike I now know. Oh, well there ya go! I shoulda thought about those options too when I did my upgrades. Quote Link to comment Share on other sites More sharing options...
