Guest zfan Posted January 24, 2006 Share Posted January 24, 2006 I have a 240Z that Iam looking at converting to a coil over set up. One of the main reasons I would like to do the swap is inner clearances. I have heard that you can gain up to 3/4" of backspace/clearance by converting to the coil over set up. Does anyone know for sure and is there an exact number gained thru the swap? If I could gain 3/4" and roll my fender lips (1/2") that would free up alot of room and that means a helluva lot more tire would fit underneath. Mike Quote Link to comment Share on other sites More sharing options...
Mikelly Posted January 24, 2006 Share Posted January 24, 2006 Mike, Between rolling the lip and doing the coil over conversion, you can gain easily 3/4 inch and maybe more. I've done both on my car and I'm running 255-40-17s under the real with zero tire sticking out past the inner fender liner. Mike Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted January 24, 2006 Share Posted January 24, 2006 Thanks Mike! Quote Link to comment Share on other sites More sharing options...
Clifton Posted January 24, 2006 Share Posted January 24, 2006 I know you can squeeze a 275 in the rear, I did. You'll have to run an 8" spring to do it though. Quote Link to comment Share on other sites More sharing options...
