New Urethane Bushings Fit Loosely Over Spindle Pin
Urethane bushing fit over spindle pin for a 1972 240Z:
I just picked up new spindle pins and checked out how the new urethane bushings that I bought from VB would slide on. They slide on very losely, There is some lateral play when holding the bushing and moving the pin from side to side. One bushing set out of the the four sets that go on the spindle is snug. Is this normal or should I return the bushings VB? I have read that some brands of bushings are too tight and require sanding/polishing the spindle pin until they slide on.
My concern is that the lose bushings will cause the spindle pins to rattle going over bumps.
Thanks
Miles
Now that you mention it I see where the nut and washer will force the washer against the control arm which will clamp the steel insert into position. Then the bushing rotates around the steel insert.
Thanks
Miles
