Turbo questions for an SR20DET
Lewis Maudlin
OK, been driving my SR20DET powered 280z around. I am interested in upgrading the turbo to reduce lag. It would be nice if it was faster spooling. I do not want to upgrade the injectors and MAF yet since I am afraid I will lose MPG's. Any suggestion on a nice driveable turbo that will reduce lag and increase power?
Also, when I watch my boost gauge, my boost spikes to 16 or 17 psi for a second or two before it drops to the 13 psi I am running. Should I be concerned about detonation? Is this just a gauge anomaly? If it is a problem, what can I do to fix it? I am running T25, cheapo aftermarket boost controller, greddy bov, ported polished intake and exhaust.
A good turbo to upgrade to would be the Garrett GT25/40R which is what I have in my '73 with an S13 SR20. I still have the stock injectors and MAF and it's running pretty smoothly with no great loss in MPG. Alex Vildini could tell you more since his shop put it in. It is a much quicker spooling turbo. It made 259 hp on the last 350Z dyno day in Wilmington, CA. I was giving those G35/350Z guys some decent competition. As far as boost spikes, mine peaks at about 10 psi before settling at 9 psi (autometer so accuracy is sketchy) I haven't heard any detonation going on, but my margin is a little closer than yours. I know you are trying to save fuel, but in my experience it's always safer to run rich than lean. BTW, how much hp is your SR pushing out?
I need to dyno mine. I am hoping I am pushing close to 275whp at 15 psi. I have a red top SR20DET
ported and polished aftermarket intake manifold
exhaust manifold with down tube
Walbro fuel pump
3" mandrel bent exhaust going to
Megan 3" inlet 4" outlet muffler (silencer removed)
Electric fan
Mine's VX ROM ECU
ACT HDSS clutch
My set up is similar to Projectrb240sx who claimed to have dyno'ed in the 250-275 rwhp range. The actual only difference I think I have may be the bigger exhaust and the Mine's VX ROM ECU. It feels like 250-275rwhp.
Bigger injectors and a bigger MAF dont lower gas mileage. At cruise speeds your AF ratios stay around 14.5 no matter how big your injectors are due to closed loop processing. The proper tunning has to be done though. With bigger injectors the duty cycle is much lower than stock, of course on boost with open loop your mileage will be less.
Guest asad137
The 25/40R isn't the best choice for a quick-spooling turbo. These days the hot setup for responsive 240sx's with SR20DET's is the GT2871R with 0.64 A/R turbine housing. The 25/40R's wheels are a bit too mismatched to produce the best response.
Other options are the GT28R or GT28RS.
Asad
Going to a larger turbo will not reduce lag. It takes more exhaust to turn a larger turbine wheel, hence higher RPM's...
At what RPM do you see full boost? Another option may be a small shot of nitrous in order to get the turbo spooled quicker..
I was looking and thinking the same thing, lagging SR turbo its T25 for gods sake, and your not going to go bigger with less lag, its just not going to happen.
You could possibly have the same responce as you have now though, but in the turbo world, usually bigger and less lag is a total oxymoron.
It think for now your money would be best spent on a EBC and some time on the dyno, then dropping a larger turbo into the car.
i dont think with stock s13 maf you can be at over 260whp unless it was tweaked. but for a faster spooling turbo with less lag, the closest you will get to that is the garrett t28 bb s15 turbo, i would definitely think about changing injectors and maf though
Asad
OK, I am thinking I am going to switch to the GT2871R. Which do I need? 0.64 A/R or 0.86 A/R? What are pros and cons? I am switching to APEXi FC with commander and Z32 MAF. The 550's will come soon. Thanks for the help
I have a gt-2871r that will be going on my sr20det. I also have the z32 MAF with the 550cc injectors, all I need now is to get the ECU reprogrammed by RsEnthalpy at 21psi and im done. In the future I will be installing a Methanol injection kit that would enable me to run 25-27 psi on pump gas. I have a gt-35r in my Evo and it compares to nothing else. Sure there's lag up till 4500rpms, then its BAM!! all the way to 8300 rpms. The benefit of a big turbo is insane top end and that ball bearing cartridge makes for the recovery time between shifts amazingly quick. The z32 MAF is good for 600whp+ reliably and should be more than enough for most sr20s. The MAF is not a restriction as some presume. In fact it is about 3 inches in diameter with nothing to hold back hp. Im sure that at insane levels of hp (600whp+) it may become inaccurate in measuring the air intake but this is way beyond my target. The stock ECU is capable of also supporting such levels of whp, therefore I decided to stick to this recipe.
I think you'll find its closer to 500fwhp.
http://autos.groups.yahoo.com/group/sr20transplants/message/27034
Not sure if everyone can see that so:
The Z32 is just calibrated to give max reading (5V) at higher airflow. So it
maxes out at about 500hp worth of air while the RB20 unit hits 5V much
earlier.
PL
Pete Leibig runs a business remapping SR.
Dave
After careful research, I am going with the GT2871R, Z32 MAF and 550's. I figure I can get at least 350rwhp reliably and still retain my cruising mpg or at least keep it over 20 mpg. I just can't resist the extra relatively inexpensive horsepower. The APEXi standalone is on its way so I don't have to have my computer retuned and retuned. I would rather have my ECU tuned on my car anyway rather than a standard tune without my car.
