Now this is a HybridZ
Lewis Maudlin
Guest tony78_280z
"Fuel consumption should be at around 12-15 Gallons per hour." Interesting way to rate gas milage? Gallons per hour. How many miles per hour you need to run to make that economical?
"Fuel consumption should be at around 12-15 Gallons per hour[/u']." Interesting way to rate gas milage? Gallons per hour. How
Gal/hr or Lbs/hr is normal for turbine operation. You typically don't have an odometer in such a vehicle :mrgreen:
If you have to ask, you can't afford it ;)
