Guest gouki Posted March 1, 2006 Share Posted March 1, 2006 I want one of these two engines and I want to compare their stats. Does any one know where I can find them? Thanks! Quote Link to comment Share on other sites More sharing options...
stony Posted March 1, 2006 Share Posted March 1, 2006 First off for the locating a rb26 question.... SEARCH the RB forums there are plenty of posts on where to buy motors from ... there are always motors on ebay to. second what is RBX-GT2? Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 1, 2006 Share Posted March 1, 2006 Third of all why isn't this in the RB forum! Quote Link to comment Share on other sites More sharing options...
Zhadman Posted March 1, 2006 Share Posted March 1, 2006 From: http://www.gtrclub.org/r33.htm Quote In 1996, Nissan released the NISMO 400R. It was based upon the R33 GT-R and there were only 99 produced. The 400R had the RBX-GT2 engine which was a further tuned version of the RB26DETT producing 400hp at 6800rpm (10,000rpm limit). A larger bore and stroke, utilizing special pistons/connecting rods, a new crankshaft and a strengthened engine block increased displacement to 2771cc. Intake upgrades also included an upgraded intercooler. Torque was increased to 346ft-lb @ 4400rpm. A 5sp gearbox was still utilized along with a twin-plate clutch to handle the connection between axle and transmission. The 400R had a revised stance thanks to a 30mm drop and Bilstein gas shocks. This and a tire size increase to 275/35/18 increased handling. Exterior changes included larger air intakes and a more aggressive spoiler. And http://images.google.com/imgres?imgurl=http://yvonne.nwwo.com/modelmain/400r_2/400r-1.jpg&imgrefurl=http://yvonne.nwwo.com/modelmain/400r_2.html&h=372&w=640&sz=62&tbnid=CcMAOvREjv8J:&tbnh=78&tbnw=134&prev=/images%3Fq%3Dnismo%2B400r%26hl%3Den%26lr%3D&oi=imagesr&start=2 Quote Link to comment Share on other sites More sharing options...
Zhadman Posted March 1, 2006 Share Posted March 1, 2006 Some More Info on the Motor: engine: RBX-GT2 Inline-6 aspiration: Twin Turbo valvetrain: DOHC 4 Valves / Cyl displacement: 2771 cc / 169.1 cu in bore: 87.0 mm / 3.43 in stroke: 77.7 mm / 3.06 in compression: 8.5:1 power: 298.3 kw / 400.0 bhp @ 6800 rpm hp per litre: 144.35 bhp per litre torque: 470.5 nm / 347.0 ft lbs @ 4400 rpm Quote Does any one know where I can find them? Good luck finding an RBX Quote Link to comment Share on other sites More sharing options...
stony Posted March 1, 2006 Share Posted March 1, 2006 AHHHH ok i have heard of the 400R but didnt know it had a differnt spec motor. Since there were so few made good luck finding one and if you do expect to pay and arm and a leg. might be able to purchase direct from nissan japan . Quote Link to comment Share on other sites More sharing options...
Zhadman Posted March 1, 2006 Share Posted March 1, 2006 stony said: AHHHH ok i have heard of the 400R but didnt know it had a differnt spec motor. That's exactly where I was at. I knew I had heard about it... but couldn't remember where. Quote Link to comment Share on other sites More sharing options...
Guest gouki Posted March 2, 2006 Share Posted March 2, 2006 Thanks guys. I've looked at those forums and found an engine I never knew of: RB30DE. It's way stronger than the RB26! Quote Link to comment Share on other sites More sharing options...
Zhadman Posted March 2, 2006 Share Posted March 2, 2006 gouki said: Thanks guys. I've looked at those forums and found an engine I never knew of: RB30DE. It's way stronger than the RB26! Why do you say that "it's way stronger than the RB26"? Beware what you read on the mis-info-net Quote Link to comment Share on other sites More sharing options...
