Owen Posted May 16, 2000 Share Posted May 16, 2000 First to Mike and the 300ZX rotor conversion. I know I will need the spacer between the hub and the rotor. Are these normal wheel spacers? Exactly how do they need to be machined? Next, Pete, regarding the rear discs. I ordered the 82-83 calipers and have the 82-83 rotors. Your article mentions Early calipers with late rotors. Can I still do this using the parts I have? I have the 83 Maxima disc brake bracket as well. Anyone know anyone who has used the RX-7 all aluminum calipers with the 300ZX rotor? Thanks, Owen ------------------ http://www.homestead.com/s30z/index.html Quote Link to comment Share on other sites More sharing options...
pparaska Posted May 16, 2000 Share Posted May 16, 2000 Owen, I believe the Maxima brackets, 82-83 rotors, and 82-83 calipers will all bolt to the 240Z-280Z series and work. I don't know about how the brake cable attaches, but I seem to remember it wasn't a huge problem. The swap I have on my site and on the tech articles page on this site is somewhat outdated by the parts you have. Some feel the extra weight and smaller pad size of the early 280ZX rear discs were not as good as the later parts you have. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted May 16, 2000 Share Posted May 16, 2000 The wheel spacers I have used are solid billet units that you just drill holes in for the mounting points on the back of the hub. Remember, the spacer is sandwhiched netween the rotor and hub. Pete is right about the early ZX vs. later ZX rear brake pads...I have the early units and the car stops well, but more pad is always better. Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Owen Posted May 17, 2000 Author Share Posted May 17, 2000 Thanks guys. Now if only I could find info on the Mazda RX-7 calipers for up front. Word is they're as big or bigger than the Toyota ones and are all aluminum. We'll see. Owen ------------------ http://www.homestead.com/s30z/index.html Quote Link to comment Share on other sites More sharing options...
