stub axle torque rating
Woah there. If you can't turn the stub axle when it gets to 110 ftlb, then something's amiss.
Are you sure that the spacer tube that goes between the bearings is the correct one for the strut housing? There are three possibilities for the length of the tube and the width of the strut housing. The strut housing (cast portion) and the spacer tube are marked with an A, B, or C. Most of them are B, but the A and C are for out-of-mid-tolerance spec. In other words, as the strut housing is made, a slight variation in the width between where the inner and outher bearings rest can occur. The three spacer tubes are made to handle that tolerance.
Did the spacers come out of the strut housings you are using? If the spacer was too long or short for the housing it could have this effect.
I can't think of another reason that the stub axle would start to bind when tightening the nut, other than the area where the bearing outer races rest isn't clean or it has a burr, or the spacer tube is the wrong one for the strut housing.
Good luck
Pete Paraska - 73 540Z - Marathon Z Project - pparaska@home.com">pparaska@home.com -
