RA64 Posted March 29, 2006 Share Posted March 29, 2006 I have a ? about the cams I can run in my E88 head the way the cams set up is now is it has an oiling rail that is worped an the ends are loose. ther is a 280z at the junk yard with n42 head with a good cam, but the cam has no oiling rail an oils from the inside Now Im not + that I can run this cam and use block off plates. Is there a better stock cam setup that I can run in the stock 2.4 with E88? Quote Link to comment Share on other sites More sharing options...
Clifton Posted April 3, 2006 Share Posted April 3, 2006 Yes you can run it on the E88. You would need the N42 cam towers also. Quote Link to comment Share on other sites More sharing options...
racerx260 Posted April 4, 2006 Share Posted April 4, 2006 If The Cams Good Just Get A Spray Bar From A 240 Or A 260. The 260 Cam In The E88 Head Has The Longest Duration Of The Stock Cams. Good On Carburated Engines. Quote Link to comment Share on other sites More sharing options...
