Z0wner 260z :::Worklog:::
Z0wner
Date: 6/18/06 (Happy Father's Day)
Time Spent: 30 minutes
Parts:
- None
Cost:
- Guy hasn't been at the shop... got to check Monday
What was done:
Yes, I feel like a gigantic chicken!
Well we did not do a whole lot because it was father's day. We did tack the other side together. Now we just need to put a good bead around each of the joints. That will be done during the week :) Also, we need to get the round tube in there and some casters. We'll prolly get this bad boy done by the next week.
Whats planned for it... finish building it, then sand blast, then paint it with steelit. Attach car and let the fun begin :)
Wow, the 1 year mark of owning the car is approaching... I wish I had the funds to get this car finished soon!
More pictures as we get farther along :-)
Problems:
- none
Pictures:
I'm still sure you can figure it out :wink:
High Resolution Pictures (Beware 56k)
-none
Link:
http://www.harwoodperformance.bizland.com/1941buick/Rotisserie(rev.2).pdf
Thanks for your time,
Z0wner
Date: 6/23/06
Parts:
- None
Cost:
What was done:
Got a decent bit done, put beads around all the joints. Not all are the prettiest, but it got the job done :). Again, we have modified the original rotisserie plans a little bit. So it is not exactly as called for.
Problems:
- none
Pictures:
623060019eo.th.jpg 623060021iv.th.jpg 623060035dh.th.jpg 623060048sy.th.jpg 623060050mu.th.jpg 623060064md.th.jpg
-none
Link:
Z0wner
Date: 6/24/06
Time Spent: 1 Hour
Parts:
- None
Cost:
- Guy hasn't been at the shop... got to check Monday... he is always gone!
What was done:
Well, everything is pretty much finished structurally. We need the casters/grease fittings/plate steel for mounting. We will hopefully blast tomorrow and then steelit on monday. Casters should be here sometime next week. I can almost see the Z on it now! :) I can not wait!
Problems:
- none
Pictures:
-none
Link:
Z0wner
Date: 6/25/06
Time Spent: 45 minutes
Parts:
- None
Cost:
- Guy hasn't been at the shop... starting to upset me...
What was done:
Sorry for lying, should have posted the other night...
Did a quick blast to remove the surface rust. Looks pretty good in my opinion. Will look better when it is in steelit (it does... trust me ;) ) casters have not come in yet because the guy hasn't been at the shop for the last week or more... he is starting to upset me...
Almost forgot, good news is... the Z will rotate 180*... for a little while we were not sure if it would :/
Problems:
- none
Pictures:
Left side is during blasting... right side is afterwards...
-none
Link:
Z0wner
Date: 6/27/06
Parts:
- None
Cost:
- Guy was at the shop, but did not have the price figured out... 9/10ths of the law is what?
What was done:
Well, we put a coat of steelit on the rotisserie. Looks really good! We also welded on the casters. Now we'll put on a second coat of steelit and call it good as done. Once it cures/dries, we will make the mounts and get the Z into the air! This thing is beautiful... moving the rotisserie is a breeze! We'll see how it goes throughout the week. I'll keep progress posted.
Problems:
- none
Pictures:
Pretty straightforward. :)
625060017xh.th.jpg625060022to.th.jpg625060039km.th.jpg625060043dn.th.jpg625060053jc.th.jpg
-none
Link:
Z0wner
How are you going to mount the car onto the rotisserie arms? The way it looks now, it seems
like the car should be mounted higher up (nearer to the pivot center) if you are to mount it up
like mine (attached to the bumper mounts)?
The arms are adjustable... so it shouldn't be a problem that can not be solved with some adjusting.
I'll make sure to get pictures of the mounts... when mounted on car etc.
Tomorrow we should hopefully have the mounts made and possibly even have the car in the air... but no guarantees
Date: 7/1/06
Time Spent: 1 hour
Parts:
- None
Cost:
- Guy was at the shop, but did not have the price figured out... 9/10ths of the law is what?... man... hmm...
What was done:
Sorry for lying...
We are airborne... Got the Z on the rotisserie! Bad butt...
Removed the front suspension, but the rear will have to wait until the 4th. We don't really celebrate with fireworks or a big family get-together, so we will have precious time working on the Z. Anyway, here are some pictures thus far.
Problems:
- none
Pictures:
Front Suspension:
Car on Rotisserie:
Mounts:
71060115qh.th.jpg 71060125yw.th.jpg 71060107yb.th.jpg 71060165fz.th.jpg 71060170dp.th.jpg
Mounts:
Link:
Z0wner
Date: 7/4/06
Time Spent: 3 hours
Parts:
- None
Cost:
What was done:
Took the rear suspension off, and lifted the vehicle to where it is going to stay. Did start scraping away at the underside, but that isn't in the pictures. It was a beautiful day. We will be starting bodywork real soon! Get the vehicle completely sandblasted and pickleXed... patch what needs to be patched... Use lead to fill in little dings/etc... Its going to be a fun time.
Starting to think about what we are going to do for body kit, etc. :D
Thinking about bolt-on flares, fiberglass front/rear bumpers... some type of airdam (type 3 msa?) headlight covers... that should probably do it just perfect :D
Problems:
- Busted my right nut... literally... a little more torque was used on a bolt than what was needed. Broke a weld, but it was a real quick fix :P
Pictures:
71060028yi.th.jpg 71060036xl.th.jpg 71060042tx.th.jpg 71060052bq.th.jpg 71060089yk.th.jpg 71060096ai.th.jpg 71060109hb.th.jpg 71060114ho.th.jpg
High Resolution Pictures (Beware 56k):
Link:
Z0wner
Date: 7/7/06 - 7/8/06
Time Spent: 8 hours
Parts:
- 800 lbs of black beauty blast media
Cost:
- I'm going to put a price sheet up tomorrow, hopefully... for blast media and rotisserie.
What was done:
I blasted and blasted the underbody of the vehicle... took so long, and still am not completely done. We did get the majority done, so I'm happy. Hopefully tomorrow the underside+engine bay will be completely blasted.
We did have some gnarly rust spots... rocker panel, floor pans, passenger firewall near floor pan, battery tray. There was a little bit of rust in other spots... Nothing to nasty though, especially when compared to some other members' vehicles.
The frame rails are top notch though. Only some surface rust. It does look like one of the previous owners jacked up the car in the wrong spots and crimped some of the metal. The vehicle is nice and straight though, so I'm happy.
The ?subframe rails? are also in top condition! there is no rust on those bad boys... well what we can see at this point. So, we won't need to replace them! Hurray!
We plan on replacing the floorpans, and patching in the other panels as soon as we finish blasting the vehicle. Hopefully, that will be done fairly soon.
Problems:
- Well, just some gnarly rust.
Pictures:
Overall:
Some of the nasty spots thus far:
Yes, It rotates 180*
Link:
- none
Z0wner
Date: 7/9/06
Time Spent: 2 hours
Parts:
- none
Cost:
- Black Beauty Blast Media 800lbs ~ $94.30
- Rotisserie Steel ~ $374.77
- Casters ~ $40.00
- Steelit ~ $30.00
- Welder Wire ~ $18.00
--- Rotisserie Total Cost ~ $462.77
What was done:
Thanks mull!
Well, ran out of time today because I had some stuff come up. So, not all that I planned on doing was done. I was able to spray a wheel well, and that was about it. Some touch-up, but not much. Either sometime during this week the underside be finished up, or this upcoming weekend.
Because there wasn't much done, I have decided not to post any pictures.
Problems:
- Again, just some gnarly rust
Pictures:
- none this update.
Link:
- none
Z0wner
Date: 7/15/06-7/16/06
Time Spent: 8 hours
Parts:
- none
Cost:
-none
What was done:
Well, continued blasting the areas on the bottom that were missed/ wouldn't come up last time. The rear panel (near the bumper) has some deep rust on it. That is taking a lot of time. Some other areas with deep rust are taking a lot of time also. Starting to frustrate me... especially when I already have 18 hours on the bottom alone. My oh my.
The bottom is not even completely finished yet. There are still some areas with the tar, and the rear (near the bumper/spare wheel well) has a bunch of deeper rust that is taking forever to come off. Then there are those nooks that just don't seem to want to come off.
Well, towards the beginning of 7/16/06 something happened to the compressor. The compressor tank will not compress more than 60psi. We have to figure what the problem is.
So, once we get the problem with the compressor figured out, the blasting will continue.
Once the bottom is "completely" finished, I plan on moving to the engine bay/ interior. Once those are finished, the exterior. We are currently looking for someone in the area that sells 18 guage steel.
I have a couple questions pertaining to body work.
- How do you do leading (using lead instead of body filler)
- How hard is it to replace floor pans? We'll probably be making our own. I've heard that the floorpans are structural... what do you do when cutting the existing panels out?
- The rocker panels are pretty close to being shot, especially the corners... where can I get replacement panels?
- Installing a fuel cell isn't very hard is it? haha, just playing :)
Problems:
- compressor broke
- bottom is taking forever and a half to blast
- sand everywhere
Pictures:
77000hikt1.th.jpg77001hinw2.th.jpg77002hizz9.th.jpg77003hiam1.th.jpg77004hika9.th.jpg
Link:
- none
Z0wner
  • 4 weeks later...
I really enjoyed reading your log bro....I actually learned quite a bit, and will probably be adopting many of your ideas....I was wondering if you ever tried filtering your blast media?? Looks like you have sand everywhere!..lol
anyway grats on the progress...my z is still my daily so no teardown until i move into a house with a garage...oh yeah and a full time job!
TB
Sorry for the lack of updates!
For the last few weeks I have been working 10 hour days... everyday except weekends
and on the weekends there has been either:
a. Family problems
b. Heat index of 100+ degrees... tried sandblasting in that, but I almost killed myself from the lack of air flow through the respirator
c. Rain... lots and lots of rain..
d. No time
Yes, we have been filtering our sand a couple times... after the third round the sand becomes pretty useless.
I am wishing I hadn't torn down the Z. I only drove it twice before tearing it apart. Now I'm regretting it.
Anyway, here is what is going on.
Depending on work tomorrow, I'll pick up the sheets of 18g steel I ordered.
We still have yet to finish blasting the Z. the interior and very few spots on the bottom, and a quick spray over the body. School starts the 21st, so... this only leaves one weekend to blast and a few of the partial days. That sucks...
So, depending on weather etc. we'll finish blasting the Z and pickling it with picklex20. Then we will buy some DTM epoxy primer and paint it at the neighbors shop. Once we do that we will actually start body work. Replacing floor pans, etc., etc.
Our neighbor owns a body shop and said he would teach me how to do a bunch of the stuff pertaining to body work and paint. He's supposedly going to show me how to paint the Z and allow me to paint it in his shop.
Anyway... I would like to get it into at least the epoxy primer... because I don't like the steel shell sitting out. It hasn't started rusting, but... I don't want to risk it.
Thanks for reading. I hope that eventually this will become a very complete and enjoyable log for anyone looking to restore/tear down their Z car.
