grumpyvette Posted April 8, 2006 Share Posted April 8, 2006 theres such a large sellection of standard cam designs available if you look thru several dozen manufacturers catalogs that theres little to be gained other than bragging material by sellecting a custom grind cam. Ive been that route several times and while it may be "COOL" it won,t be likely to boost your power significantly over the results youll get from a similar off the shelf design thats available from at least one manufacturer,keep in mind MOST manufacturers keep aN EXTENSIVE LOBE library and can match the lift.durration and LSA you want on a standard core easily,and most manufacturers have HUNDREDS of non-listed cam designs available simply because they don,t have space to list the less popular sellections CRANE 386-258-6174 CROWER 619-661-6477 ISKY 323.770.0930 ENGLE (310) 450-0806 ERSON 775.882.1622 DOUG HERBERT 1-800-444-7373 MELLING 517.787.8172 Schneider Cams 619) 297-0227 LUNATI 1-888-2012066 Cam Techniques http://www.camtechniques.com/ CamCraft Cams http://www.camcraftcams.com/ Comp Cams http://www.compcams.com/ Crane Cams http://www.cranecams.com/ Crower http://www.crower.com/ Daytona Cams http://www.camshafts.com/ Delta Cams http://www.deltacam.com/ Chet Herbert http://www.chetherbert.com/ Howard's Racing Components http://www.howardscams.com/ Iskenderian Racing Cams http://www.iskycams.com/ Lazer Cams http://www.lazercams.com/ Lunati http://www.lunaticams.com/ McGurk Engineering http://www.waynemfgco.com/ Melling Automotive Products http://www.melling.com/ Reed Racing Cams http://www.reedcams.com/ Schneider Racing Cams http://www.schneidercams.com/ Shadbolt Cams Limited http://www.shadboltcams.com/ Clay Smith Cams http://www.claysmithcams.com/ UltraDyne http://www.ultradyne.com/ trust me! (this is only a small part of the available sellection)one of these manufacturers have something almost exactly matching your needs Quote Link to comment Share on other sites More sharing options...
jakeshoe Posted April 9, 2006 Share Posted April 9, 2006 A "custom" cam usually consists of a regular shelf stock lobe configuration but with a different LSA or a split pattern that isn't available stock. It's not that anybody is designing a specific lobe for you, just using what's already there. I almost always select a "custom" grind based on the engine and intended usage. The cost is usually minimally more (if any) than a shelf grind. Often there are other reasons to use a custom grind, as in the case of the austempered iron CAST cams used by Comp and others now for a street roller. My advice is to NOT use this type of core. Call and order the grind you want on a billet core, and if used on the street get it with a cast dist gear pressed on the back so you can run a conventional distributor gear. I personally use http://www.deltacam.com for most of my stuff. They can grind on a new or used core about any profile you need. Many of their lobe masters are Comp Cams masters, so you can get a "Comp" cam with better quality control for cheaper. Quote Link to comment Share on other sites More sharing options...
Michael Posted April 9, 2006 Share Posted April 9, 2006 One specific instance that might call for a custom cam (or a semi-custom cam, as Jakeshoe points out), is when you want to run a mechanical roller, but happen to be interested in a low-rpm application, for which all of the cams in the catalog are too big. Quote Link to comment Share on other sites More sharing options...
331CI 280z Posted April 10, 2006 Share Posted April 10, 2006 This is Lunati's cam recommendation for me. Solid Roller P/n 51099 - grind number rrn-ur55-ur29 108 dur251-261 @.050 .669- .669 lift with 1.6 rr lobe sep 108 rpm 3500-7800 Quote Link to comment Share on other sites More sharing options...
John Scott Posted April 10, 2006 Share Posted April 10, 2006 I've used the custom grind a few times, but for applications where only a few were available. Case in point, late 80s before the 4.3 became popular, there were no options, CC was the only company with blanks, not regrinds, willing to custom grind for my NA motor, 108 lsa, and then later for a supercharged application, 114 lsa. Now with a gaZillion profiles availible, one is bound to be a good match. Its still a good idea to call with your engine and vehicle specs to get a good match, but typically get a slightly different recommendation day to day. Quote Link to comment Share on other sites More sharing options...
jakeshoe Posted April 10, 2006 Share Posted April 10, 2006 Just a bit of information... There is nothing wrong with a properly done regrind.. A reground core can save you money and in some cases is as good as or better than a new core. A reground core, especially for about any American V8 is not going to be "welded up" it will be from a good used core that lasted many thousands of miles. That tells you it is properly hardened... On a motor with an adjustable valvetrain, I will select a regrind for most flat tappet builds for that reason. If you need a small base circle cam for a stroker motor, guess what, you may as well get a regrind, because the smaller base circle is oftentimes the same blank as a stock size base circle but ground down further. I've ran literally hundreds of regrinds in my own and customers motors and never had any issue. How many can say they have had a flattened lobe on a new cam...? Quote Link to comment Share on other sites More sharing options...
331CI 280z Posted April 10, 2006 Share Posted April 10, 2006 My local machine shop, Eastwood Auto Machine has had a few bad cams from Comp lately. They were all flat tappet, and they sent the cams to Comp for analysis and were awaiting the results the last I spoke with them. They thought that Comp may have changed the material formulation in their flat tappets. Quote Link to comment Share on other sites More sharing options...
jakeshoe Posted April 11, 2006 Share Posted April 11, 2006 Another tibit of information, Comp does NOT make cam cores. There are 3 major cam core companies that everyone buys cores from. Cam cores are hardened before grinding by the core manufacturer in most cases (as far as I know except for the OEM rollers made from 8620 material IIRC). Some of the problems in the last few years have been core related, some have been quality control related, some have been lifter related, and some I believe to be cam companies getting a little too aggressive with their flat tappet profiles. Quote Link to comment Share on other sites More sharing options...
