vega Posted April 9, 2006 Share Posted April 9, 2006 those of you with fuel inject turbo l28 what kind of MPG are you getting and what kidn of power ware you puting to the ground? Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted April 9, 2006 Share Posted April 9, 2006 Stock 3 speed auto no mods was getting me 18mpg. With a 5 speed manual and an aftermarket ECU you can probably hit 30mpg on the highway. Mario Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted April 9, 2006 Share Posted April 9, 2006 Mine is making in the neighborhood of 350-400 depending on boost level. SDS and 450cc injectors 28mpg no problem on the highway. Quote Link to comment Share on other sites More sharing options...
olie05 Posted April 10, 2006 Share Posted April 10, 2006 Quote Mine is making in the neighborhood of 350-400 depending on boost level. SDS and 450cc injectors 28mpg no problem on the highway. Really? Is that on or off boost on the freeway? sorry for the ignorance, i've never owned or driven a turbo car for extended periods of time to know if being on boost is normal for freeway driving (most of the driving time was ON BOOST!!!)... Just curious! Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 10, 2006 Share Posted April 10, 2006 17mpg in the city Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted April 10, 2006 Share Posted April 10, 2006 olie05 said: Really? Is that on or off boost on the freeway? sorry for the ignorance, i've never owned or driven a turbo car for extended periods of time to know if being on boost is normal for freeway driving (most of the driving time was ON BOOST!!!)... Just curious! Nope thats just cruising, typically between 10-15 in/hg. And just in case it matters, cruising at 75mph, 37-40 degrees total timing, about 15.0-15.5 AFR's, and around 1300 EGT's. Quote Link to comment Share on other sites More sharing options...
Thumper Posted April 10, 2006 Share Posted April 10, 2006 I got 24-25mpg in my last 800mile trip. That was doing 80-90mph. But i'm running megasquirt. Also 8-14 inHg Quote Link to comment Share on other sites More sharing options...
george.bryant Posted April 10, 2006 Share Posted April 10, 2006 I want to work this out. I dont like the imperial system with all its odd figures. How do i convert Litres per KM to MPG (vice versa)?? Quote Link to comment Share on other sites More sharing options...
olie05 Posted April 10, 2006 Share Posted April 10, 2006 http://www.crxsi.com/convert.htm 28 Miles per Gallons equals 8.40 Liters per 100 Km 17 Miles per Gallons equals 13.84 Liters per 100 Km 24-25 Miles per Gallons equals 9.80-9.41 Liters per 100 Km Quote Link to comment Share on other sites More sharing options...
Drax240z Posted April 10, 2006 Share Posted April 10, 2006 232rwhp, 281ft-lbs. 25-28mpg highway using a stand alone ECU. Probably could get better milage if I tried to. Quote Link to comment Share on other sites More sharing options...
zbuild Posted April 12, 2006 Share Posted April 12, 2006 230rwkw (308hp), 15psi, L28, Motec computer, highway cruising with wife in car 28-30mpg - wife out of car - scarey Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted April 13, 2006 Share Posted April 13, 2006 zbuild said: 230rwkw (308hp), 15psi, L28, Motec computer, highway cruising with wife in car 28-30mpg - wife out of car - scarey with wife out of car . . . 10mpg . . . cause that means you can stick your foot in it! HAHA Quote Link to comment Share on other sites More sharing options...
Guest Z Draci Posted April 17, 2006 Share Posted April 17, 2006 Before I took then engine out, my fully stock 280ZX turbo did an average of 20mpg no matter how I drove it. It was about 85% city and 15% highway. Quote Link to comment Share on other sites More sharing options...
george.bryant Posted April 18, 2006 Share Posted April 18, 2006 I'm getting around 20mpg on a L20et, with a stuffed automatic, 1 bar boost. Seems to vary alot. I think i've finally found the sweet spot for timing and sorted my idle problems out so I should use a bit less Petrol is NZD $1.76 (USD $1.10) a litre here (thats 95). How much does everyone else pay? It's going up $.06 everyday for the last week... Quote Link to comment Share on other sites More sharing options...
lifegrddude Posted April 18, 2006 Share Posted April 18, 2006 I'm averaging about 16mpg with a set of 370s and bumped up fuel pressure on a 3spd a/t. It was at 18mpg before the injector swap. Hopefully I'll hit the mid 20's this summer when I change over to a 5spd. Quote Link to comment Share on other sites More sharing options...
george.bryant Posted April 18, 2006 Share Posted April 18, 2006 How did you bump up your fuel pressure? I have a TurboSmart Fuel Pressure Regulator i just need to fit it. Quote Link to comment Share on other sites More sharing options...
