280Z Turbo Posted April 23, 2006 Share Posted April 23, 2006 I've been searching around for this, but there isn't much out there about pinion flanges/seals because it's not a job that people like to do! I just removed the flange from my '84 Turbo R200 and now I want to remove the front seal, but I can't seem to get it out. What's the best way to do this? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 23, 2006 Share Posted April 23, 2006 I just used a seal puller. You could probably also use a screwdriver. http://www.autobarn.net/lis56750.html Quote Link to comment Share on other sites More sharing options...
280Z Turbo Posted April 23, 2006 Author Share Posted April 23, 2006 I tried a screwdriver. It's REALLY stuck in there! I don't know what to do. Quote Link to comment Share on other sites More sharing options...
VRJoe Posted April 23, 2006 Share Posted April 23, 2006 You could try this http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=4876 - Joe Quote Link to comment Share on other sites More sharing options...
Mike C Posted April 23, 2006 Share Posted April 23, 2006 With the pinion still installed, it's a little more difficult. Just use a hammer and screwdriver. You will tear it up, but since the goal is to replace it, doesn't matter anyow. Just hammer it in, out, left, right, push, pull, pry and it will come out. Then install the new one carefully tapping with a hammer. Most seal installers are flush so won't work with the pinion still in the case. Quote Link to comment Share on other sites More sharing options...
280Z Turbo Posted April 23, 2006 Author Share Posted April 23, 2006 I used a punch to make a hole then I put a wood screw through the hole and used that to pry on with a hammer. And then it popped right out! I just hope I wasn't being too rough on the bearing. Quote Link to comment Share on other sites More sharing options...
