big-phil Posted April 25, 2006 Share Posted April 25, 2006 I'm selling this on e-bay and I getting questions I can not answer. Also would this fit and work on an L28ET? Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 25, 2006 Author Share Posted April 25, 2006 I'm selling this on e-bay and I getting questions I can not answer. Also would this fit and work on an L28ET? It has no waste gate but is that a T3 flange? Quote Link to comment Share on other sites More sharing options...
nienberg.11 Posted April 25, 2006 Share Posted April 25, 2006 Phil, aren't you able to measure the flange on your own t3 as well as the spacing of its bolt holes for comparison? Might have to get dirty to get the measurements, but still... Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 25, 2006 Author Share Posted April 25, 2006 Yea I thought I would throw it out there. Time to put on the rubber gloves. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted April 25, 2006 Share Posted April 25, 2006 is that a CT26? mike Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 25, 2006 Author Share Posted April 25, 2006 well its bigger than a T3 Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted April 25, 2006 Share Posted April 25, 2006 is that a CT26? mike n/m its not.. couldnt see it on the other computer very well. does look like a T4 flange Quote Link to comment Share on other sites More sharing options...
Clifton Posted April 25, 2006 Share Posted April 25, 2006 I'm selling this on e-bay and I getting questions I can not answer. Also would this fit and work on an L28ET? T4 for sure. Will it work on an L28? Yes. How well depends on the turbine a/r. It looks big though. Knowing the specs would help you sell it. Measure the wheels. Quote Link to comment Share on other sites More sharing options...
zguy36 Posted April 26, 2006 Share Posted April 26, 2006 Clifton.. I like the new avatar! Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 26, 2006 Author Share Posted April 26, 2006 T4 for sure. Will it work on an L28? Yes. How well depends on the turbine a/r. It looks big though. Knowing the specs would help you sell it. Measure the wheels. I took the intake side off and it measures 2.75 inches inside the hot side it has 1.15 stamped in it. Oh and on the cold side it has it has a stamp on one of the fins, a circle with R O 64, I think it says R O its hard to see Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 26, 2006 Author Share Posted April 26, 2006 OK so if the A/R #'s of this turbo says it will work with the L28 should I get this? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8058686561&fromMakeTrack=true Quote Link to comment Share on other sites More sharing options...
Clifton Posted April 26, 2006 Share Posted April 26, 2006 I'm 99.9% sure it's a P trim wheel on the hot side. A 1.15 would be way too big. A .58 would be best for the street, a .68-70 would work okay. What's the inducer on the compressor wheel? Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 27, 2006 Author Share Posted April 27, 2006 2 5/8 in and 1 3/4 out on the cold side is that what you ment? Quote Link to comment Share on other sites More sharing options...
Clifton Posted April 27, 2006 Share Posted April 27, 2006 2 5/8 in and 1 3/4 out on the cold side is that what you ment? That's the compressor in/out. You need to remove the compressor housing(cover) and measure the compressor wheel. Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 27, 2006 Author Share Posted April 27, 2006 oh the wheel at the biggest part was 2 3/4 inches Quote Link to comment Share on other sites More sharing options...
Clifton Posted April 27, 2006 Share Posted April 27, 2006 oh the wheel at the biggest part was 2 3/4 inches What the wheel at the smallest part? It can't be 1 3/4". Are you using calipers or a tape measurer? Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 27, 2006 Author Share Posted April 27, 2006 2 3/16 at the smallest part of the wheel Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 28, 2006 Share Posted April 28, 2006 just go Holset Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 28, 2006 Author Share Posted April 28, 2006 I think I might If I can find one for the right $$ Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 28, 2006 Author Share Posted April 28, 2006 what about this? Is this just cheap crap? http://cgi.ebay.com/ebaymotors/T3-T4-T04E-57-TRIM-TURBO-TURBOCHARGER-BOOST-CONTROLLER_W0QQcmdZViewItemQQcategoryZ33742QQitemZ8059068478QQrdZ1 Quote Link to comment Share on other sites More sharing options...
