oil plug thingies
Silent
pokin through the "how to modify your datsun" book last night while watchin cartoons {yes i still watch cartoons} the plug, right above the timing tensioner. why is this sucker plugged? same on the back side of the motor? why?
more oil pressure? more pressure to the head? im at a loss here.
No plugs = no oil pressure = bad day....
This was most likely part of the block machining process - the oil galley was created by boring a long hole through the block in a precise location. In order for it to work, the ends of the galley have to be plugged, else the oil would just bleed out either end, as others have stated. The plugs also allow you to clean out the galley during a rebuild.
You can't leave them out, though.
This was most likely part of the block machining process - the oil galley was created by boring a long hole through the block in a precise location. In order for it to work' date=' the ends of the galley have to be plugged, else the oil would just bleed out either end, as others have stated. The plugs also allow you to clean out the galley during a rebuild.
You can't leave them out, though.[/quote']
Yeah, probably should have mentioned that. You can get ones that you just hammer in, or you can tap the hole in the block and use 3/8" pipe plugs. You have to be careful though, because the galley that pressurizes the tensioner is right inside the front of the block, so if you put the pipe plug in too deep you can block it off. Don't want to do that!!!
