Ariel Atom
v80z
the shocks are easy...just go to summit or someplace...
To bend the tubing like that you would need a scroll tubing bender...$$$$
or you could get a new warrior dune buggy chassis with prebent tubes for $250 and then modify it with control arms instead of the VW bug running gear and maybe a SR20DET out back with a front wheel drive tranny. it would not be THAT hard.
just don't weld on the roll tubes on top and you are set.
USA left hand drive version:
Price: $35,000.oo to $45,750.oo depending on engine configuration.
Brammo Ecotec 2.2         $35,000              145 HP/ 155 Ft./lbs.
Brammo Ecotec 2.4         $38,000              171 HP/ 163 Ft./lbs.
Brammo Ecotec 2.0 SC      $40,000              171 HP/ 163 Ft./lbs.
Honda K20                 $40,250              USDM K20z3 200-225HP
Honda K20 SC              $45,750              290-300HP
High res. video (40mb)
Low res. video (17mb)
More info here.
just build a locost 7. the newer chassis are using miatas as donor cars.
http://www.domsat.co.uk/pages/locost.htm
http://locost7.info/locost.php
http://locostusa.com/
http://www.rhinobuggies.com.au/the_locost.htm
http://www.grmotorsports.com/archives/locost.html
I figure that as soon as things start to settle down in my life and I plant myself down on a patch of earth I will start building a miata suspension based 7 using a hayabusa engine (or the V8 version should funds allow) even a renisis powered 7 would be super fun.
Guest BiltWel
That thing is Badass I just think of it as an overengineered Gocart though. But a Badass one. If my wife told me I needed one of those I would not hesitate I would go straight to wherever it was sold and be wrinkling face that evening.
