280zwitha383 Posted May 4, 2006 Share Posted May 4, 2006 My 383 keeps moving my starter away from the flywheel (I think). It's a new mini-reduction starter and I didn't have any stock bolts to put in it so I went to the hardware store and got some. After a while of using it, the starter will move away from the flywheel so I can loosen it and move it back and tighten it up again and it will work fine for a little while. The last time I repositioned it I was curious what was going on so I crawled under the car and watched it crank a few times and it was moving side to side while it was cranking but the bolts were tight. So what I'm wondering is if the shoulders on the bolts are not big enough to keep the starter in place would that make it move side to side. I'm assuming it's not supposed to move at all. Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
Alf Posted May 4, 2006 Share Posted May 4, 2006 What kind of bolts are you using? Are they threaded all the way up or do they have some type of shoulder? I know the stock starter bolts have a shoulder with a cross hatch pattern on them that fit tight in the starter housing and hold it from moving anywhere. I think if you go get some regular starter bolts your problem will be solved, unless the starter was machined wrong. Quote Link to comment Share on other sites More sharing options...
280zwitha383 Posted May 4, 2006 Author Share Posted May 4, 2006 Hmm, looks like the "similar thread" function works a little more efficiently than the "search" function. http://forums.hybridz.org/showthread.php?t=71345 I think you may be right! (edit: the bolts I have are shouldered but I'm guessing not enough) Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted May 4, 2006 Share Posted May 4, 2006 use a higher grade as well, napa truck supply usually has a great selection. Quote Link to comment Share on other sites More sharing options...
pparaska Posted May 4, 2006 Share Posted May 4, 2006 Sounds like maybe the flywheel gear is not at a constant radius from the crank centerline, making the starter move around? You may be just looking at a symptom of that, the starter getting loosened. Quote Link to comment Share on other sites More sharing options...
jakeshoe Posted May 4, 2006 Share Posted May 4, 2006 Yes, Starter bolts do matter. Until you get a proper bolt it will continue to move around. The correct bolts are knurled and maintain a large diameter approx 1/4-3/8" into the block. Look at the bolt holes in the block, they are counterbored for the correct bolts. If you use the wrong bolts, you will eventually break one in the block, and possibly break the ear off the block. Quote Link to comment Share on other sites More sharing options...
280zwitha383 Posted May 5, 2006 Author Share Posted May 5, 2006 I was thinking one of the bolts went in kinda funny. Man I'm getting some bolts asap. I guess parts stores would have them? Quote Link to comment Share on other sites More sharing options...
