is this B.S?? Diesel "Magnetic Cyclonification"
260ZRED
Anyone watch Mythbusters last night? They tested the magnets, a 300 mpg carburetor, and an electrolysis thing that produced hydrogen which was supposed to run the car. None worked of course, but it was pretty entertaining when they took a tank of compressed hydrogen and got one of the cars to run on it just by blowing a little hydrogen directly into the carb. Thought that was pretty cool!
Your car should run pretty clean on hydrogen, although in order to get the same range as gasoline, your gas tank would have to be 2.75X bigger and store it either at -253C or at an extreamly high pressure no doubt 20ga sheetmetal wouldn't be enough, so you'll add weight there.
http://www.clean-air.org/Hydrogen%20Cobra%20Story/Hydrogen%20Cobra.htm
jmortensen
if you think metalic dust in the gas works you need to try CARBORUNDUM paste valve grinding compound added to your OIL, it almost instantly increases the bearing clearances, increases oil flow,lowers oil flow resistance thru the engine, increases valve guide clearances. loosens rockers, pollishes lifter bores and generally increases oil flow everywhere
why have all that power robbing friction when smply adding a single $4 tube to your oil will remove a good deal of the contact area between the cylinder walls and rings
Your car should run pretty clean on hydrogen' date=' although in order to get the same range as gasoline, your gas tank would have to be 2.75X bigger and store it either at -253C or at an extreamly high pressure no doubt 20ga sheetmetal wouldn't be enough, so you'll add weight there.
You should check this. Read on the amount of hydrogen they can store using there method. Hydrides. http://www.switch2hydrogen.com/h2.htm
There is something extremely fishy about that site. They list all these products and make all these claims about what they can do, but none of their products are actually available yet, all the prices are approximate, they say don't call them because all of their info is on the web site and yet their web site is basically nothing but a top level sales brochure. Plus they cry "the government" is trying to shut them down.
Plus their claim that there solar generator will make hydrogen "at near zero cost" is totally moronic. They don't have a price on their hydrogen generator, but they do sell 80 watt solar panels (at $425 each) and say it takes a minimum of 5 to run the hydrogen generator. With only 400 watts of output and figure a 70% hydrogen conversion efficiency, that $2125 solar panel + hydrogen generator might kick out enough hydroden to equal about a gallon of gas a week. And that is only if the sun shines all week.
This link
http://www.aip.org/tip/INPHFA/vol-10/iss-1/p20.html
talks about hydrides and says a tank large enough to hold 5 kg of hydrogen (maybe 10 gallons of gas) weights 360 kg. Did they really add a 1500+ pound tank to that vette to get their 450 mile range?
