n42 head on turbo motor?
I'm want to increase the off boost tourqe on my turbo motor.If I use a n42 head on a turbo low end I should end up with about a 8.4 cr depending on the head gasket.How much boost is safe to run with the stock ecu and no intercooler?I live in the mountains and I need tourqe more than peak h.p.With the dished pistons and the n42 head chamber I will be at more risk for detonation , would a 1 mm hd gasket be best? I have read that the head temperature sending unit for the turbo can be moved to the thermostat housing ,will that work ok? And lastly if iI did run an intercooler how much boost could I run with this setup?I have done many serches and found great info but am con cerned about the specifics listed above.
I am pretty sure that the N42 is going to be too much for a turbo... unless you are going to change the pistons...
I am not the most proficient on the L6ET... I would think without the intercooler... you could bump it a few psi, but not much, you will have to watch for detonation...
It would be very wise to get an intercooler for running higher boost levels... even a small one..
My last motor with forged pistons and an N33 head was right at 8-1 with a 1mm NISMO head gasket.The current setup uses an N42 head that has been ported and ceramic coated and the comp is 8.5-1 with forged pistons and a 1mm head gasket. With the ceramic coating combustion chamber heat is more evenly distributed.You might want to look into a methanol injection kit in addition to your intercooler to help with detonation .
http://pg.photos.yahoo.com/ph/sss510six/detail?.dir=63ef&.dnm=2b09.jpg&.src=ph
http://pg.photos.yahoo.com/ph/sss510six/detail?.dir=63ef&.dnm=d75c.jpg&.src=ph
http://www.coolingmist.com/
Thanks for the imput but I'm still wondering how much boost are we talking here?can I run a stock 7 lbs of boost with no intercooler or would I need one just to run 7? I've seen many posts with hp info on low compression turbo motors with various mods and boost levels but not much on what to expect with n/a level cr and low boost levels.Any one with numers on what I could expect?
