sb280z Posted July 6, 2006 Share Posted July 6, 2006 I am getting ready to do a 5.0 swap into my 76 280z and had a question to ask the forum. Is there one particular year 5.0 that is a better choice for the swap than another. I have a lead on a 86, 5speed, complete mustang and was curious if there was anthing inherintly bad about this year? Quote Link to comment Share on other sites More sharing options...
LMoore56 Posted July 6, 2006 Share Posted July 6, 2006 Don't get an 86 model. If you want EFI, get 87 and up. The 87 & 88 came with the speed density system and 89 & uphad the mass air setup. There is something about the pistons in the 86 model. If you change heads, the valves hit the pistons. The heads also have a different chamber. Quote Link to comment Share on other sites More sharing options...
sb280z Posted July 6, 2006 Author Share Posted July 6, 2006 I was told this was a fuel injected motor. Quote Link to comment Share on other sites More sharing options...
LMoore56 Posted July 6, 2006 Share Posted July 6, 2006 It is, but you can't modify it very well. If you do, you will need to change the pistons. Quote Link to comment Share on other sites More sharing options...
sb280z Posted July 6, 2006 Author Share Posted July 6, 2006 Thank you for the info, back to searching for a donor car. My Z and now this 5.0 is the first time I have ever delt with EFI. My other toy is carberated. Quote Link to comment Share on other sites More sharing options...
s3079893 Posted July 6, 2006 Share Posted July 6, 2006 From my 'limited' experiance with the SBF. I found that if you are planning on making 'highish' power (350-400hp (flywhhel) ) it's ALOT cheaper to go carby. I bought an EFI windsor and im converting it to a carby strait lpg/propane setup because of this. Quote Link to comment Share on other sites More sharing options...
David K Posted July 11, 2006 Share Posted July 11, 2006 sb280z said: Is there one particular year 5.0 that is a better choice for the swap than another. Yes. You should shoot for 89 and up if you are going with fuel injected. 87 and up have forged pistons. Go here and see a list of changes for each year. http://mustanggt.org/gtchange.htm Quote Link to comment Share on other sites More sharing options...
