fuel pump relay
Hi i'm looking for the location of the fuel pump relay in a 75 280z, is it a separate relay or the combo one that is part of the fuel injection relay that is over by the ecu?
i'm doing an RB swap and want to know where to run the pump signal to.
if it is the combo fuel injection relay then I'll get a genaric 30amp relay and just wire it in.
Thanks
Chris Rummel
Nobody knows? I'm starting to think the 75's fuel pump didn't have a relay, and maybe just was wired to a 12volt hot. I guess I'll just have to trace the wires back from the fuel pump and find out for myself.
I'll likely just run a generic 30amp relay with separate wires anyway.
Chris
  • Administrators
Hi,
Its located under the dash, nearby the steering column. It looks about the size of two standard relays side-by-side. It has two plugs attached to it (becuase its actually two releys, main and fuel pump) If memory serves, one plug is black and one is clear.
HTH
