JaysZ Posted July 21, 2006 Share Posted July 21, 2006 i tried to push these in and the brass bushings ended up getting bent out of shape... i believe I have a stick from a '77. any ideas? should i try to do the freeze + heat method? Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted July 21, 2006 Share Posted July 21, 2006 Are you sure you got the right ones? I had to lightly sand mine and with a little peice of wood and a hammer they went right in. Mario Quote Link to comment Share on other sites More sharing options...
JMortensen Posted July 21, 2006 Share Posted July 21, 2006 What's wrong with the Nissan plastic bushings? They're still available last I checked, they cost about $6, and they last for 20 years... Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted July 21, 2006 Share Posted July 21, 2006 These cost ~$3 and they are a lot tighter then even new Nissan bushings. These should last more then 20 years haha. Mario Quote Link to comment Share on other sites More sharing options...
JMortensen Posted July 21, 2006 Share Posted July 21, 2006 Can't argue with that logic. I thought they were more expensive. Quote Link to comment Share on other sites More sharing options...
JaysZ Posted July 21, 2006 Author Share Posted July 21, 2006 the plastic ones i have are still in good condition, but like Mario said, the metal ones offer a tighter fit and... its metal $2.99 at Autozone the outside diameter is just a tad too big but the inside diameter seems to be spot on. the part # i'm using is # 38377 which is the proper one according to the tutorial i printed. i may end up just sanding out the outside ring a bit and work it in there. i'll need to order more, the last one i tried to bang in is a little warped now lol Quote Link to comment Share on other sites More sharing options...
veritech-z Posted July 22, 2006 Share Posted July 22, 2006 I just made a new one out of a plastic bushing I got from ACE hardware. Cost me $.20, plus a bit of my time to "adjust" the fit. It's super tight, and I haven't had any problems so far. Quote Link to comment Share on other sites More sharing options...
