400whp L28?
Guest Cronic
Your ring lands will be fine as long as it doesn't knock. You are using 108 so it's all in the timing, don't get greedy. I've run 22 psi, up to 24 psi all day long on the track with stock pistons on an L motor. 30 psi +(gauge only goes to 30) on the 7M with stock cast pistons. I think turbo will be limiting you unless you, especially if it's a standard turbine wheel. Were did the Supra 550's come from? Only MKIV's had them and they are side feed.
Same here. I'll be trying 24psi then 26 psi on zx in the next couple of weeks at the track. Water injection is a VERY good friend to take along for the ride. That's with 91 octane and meth.
Guest Cronic
They're MK3 injectors, sorry about the misprint. 440's!
