I thought you guys might like this..
I thought you guys might like this, its a well designed 383 stroker that produces almost big block power...notice the 246cc port heads and the roller cam, while its not a street engine it could be run on pump gas
385 Cu.In.
10.5:1 cpr
GM 4 Bolt "010" Block
4.04 Forged SRP pistons -16cc
Eagle Cast 3.75" Crank
Crower 6.0" 4340 I beam rods
Crower Billet Steel ROLLER Cam 254/257 @ .050 .712 lift w/ 1.6 rockers 108* LSA installed at 104*
Jesel Shaft Rockers 1.6:1
PSI Springs 230# closed, 620# open
Super Victor Intake ported to match heads, Fel-Pro 1209
Wilson Manifolds 1.5" carb spacer
Holley HP950 Carb, 79-81 jets, .055 air bleeds all the way around
MSD Pro-Billet Distributor
Custom Stepped headers 1.75 - 1 7/8 - 2"
Iron Eagle Platinum 230cc (246cc after port work)
Heads CNC'd by M2 Racing 320cfm @ .700 333 cfm @ .800
66cc chambers
42* total timing
110 octane on dyno will run 91 on street
It's a custom billet steel ROLLER cam. Youll need to order one
282/286 adv
254/257 @ .050
.445 lift @ lobe
.712 lift w/ 1.6:1 rockers
108* LSA
104* ICL
Solid Roller
450tq 580hp
http://i5.photobucket.com/albums/y197/stevemc1979/finaldyno.jpg
http://i5.photobucket.com/albums/y197/stevemc1979/finaldynonumbers1.jpg
http://i5.photobucket.com/albums/y197/stevemc1979/finaldynonumbers2.jpg
http://www.crower.com/misc/contact.shtml
Sweet engine Grumpy!
One question: did you try any pulls with less timing? I was under the impression that the Iron Eagle heads actually performed best with around 36-38* total advance. I'm not an expert though, so there is likely another variable in the equation that I'm missing.
0.712” lift in a SBC is HUGE! I have to wonder - if they went with a shaft rocker system and a commensurately race-oriented valvetrain, why did they not use aluminum heads, and why did they limit themselves to 385 cubic inches? This engine could evidently get decent volumetric efficiency even approaching 7000 rpm - but at that point, would the bottom end still be reliable?
