modifying the stock turbo
evildky
anyone ever just modify the stock turbo? I want to change out the compressor side but cant get the compressor wheel off, the nut or bolt on the exhaust side is quite unique, anyone know of a special tool or special trick to get this thing apart?
I've seen atleast one turbo shop that had a tool that held the turbine wheel by the blades. I had one I couldn't get loose as the nut was trimmed alot from balancing. I wrapped a rag around the turbine blades and held that and had someone else break the nut loose on the other end.
