260DET Posted August 4, 2006 Share Posted August 4, 2006 Seem to recall something about the single turbo having lower lift cams than the TT. Any ideas anyone? Quote Link to comment Share on other sites More sharing options...
Guest ZFury Posted August 9, 2006 Share Posted August 9, 2006 If you are wondering if you can swap TT cams and T cams. No. TT's have DOHC, while single T are SOHC. Cam configureation is different plus the TT has more valves. Just completely different heads. Hheheh', just noticed how old this post was... and I was the first to reply!? Quote Link to comment Share on other sites More sharing options...
RedBeauty84ZX Posted August 9, 2006 Share Posted August 9, 2006 ^^^ Your getting the VG30DET and VG30ET confused. In Japan and Austraila they had the VG30DET in some models, it was based off the VG30DETT. Quote Link to comment Share on other sites More sharing options...
260DET Posted August 10, 2006 Author Share Posted August 10, 2006 Found a figure for the TT cam lift, just have to measure a DET cam now and compare Quote Link to comment Share on other sites More sharing options...
RedBeauty84ZX Posted August 14, 2006 Share Posted August 14, 2006 Does any one know if the VG30DET or VG30DE(used in the 300ZR not in Z32) have VVT? Quote Link to comment Share on other sites More sharing options...
260DET Posted August 14, 2006 Author Share Posted August 14, 2006 Very much doubt it, basically the early VG30DET's did not, the later ones did. Don't ask me to define early and late. Quote Link to comment Share on other sites More sharing options...
RedBeauty84ZX Posted August 14, 2006 Share Posted August 14, 2006 Very much doubt it, basically the early VG30DET's did not, the later ones did. Don't ask me to define early and late[/i']. Do you have any sources? I have heard that the 300ZR using the VG30DE used NVCS(VVT) in 1986. Quote Link to comment Share on other sites More sharing options...
260DET Posted August 15, 2006 Author Share Posted August 15, 2006 Only sources are the use of the VG30DET in JDM cars other than the 300ZR, which is a choice car BTW. Quote Link to comment Share on other sites More sharing options...
Guest ZFetsh Posted September 10, 2006 Share Posted September 10, 2006 I know for a fact that the VG30DET (from a Y32 Cedric) has variable valve timing - theres one sitting in my garage atm! The plugs are different however, and I have no technical information on the cams Quote Link to comment Share on other sites More sharing options...
Beck Posted September 13, 2006 Share Posted September 13, 2006 Most of the cams are identical from one motor to the other(same exact part numbers). The timing varies between some of the cams, but lift is unchanged. I have the list of cams somewhere. Let me know what you want to know specifically. Quote Link to comment Share on other sites More sharing options...
260DET Posted September 13, 2006 Author Share Posted September 13, 2006 Looking through the Z32 workshop manual I noticed that the autos had slightly different cams. Seeing mine is a JDM auto engine...... Quote Link to comment Share on other sites More sharing options...
Zdaddy Posted March 22, 2008 Share Posted March 22, 2008 VVT was a key feature of the VG30DE/DET/DETT. The only ones to not get the VVT were those made from 1996 and up. That means the Z32 during those years lost VVT and the Z32TT lost 20BHP as a result. For more information, visit the VGPowered Forum http://www.vgpowered.com/forum Quote Link to comment Share on other sites More sharing options...
Guest fabman Posted March 31, 2008 Share Posted March 31, 2008 i have some spare cams that i got with my electramotive gtp vg30 motors i think there 286 615 102 lobe cl there turbo cams Quote Link to comment Share on other sites More sharing options...
