2jzgte240z Posted August 21, 2006 Share Posted August 21, 2006 just got su carbs installed on my 73 datsun... its the stock motor that comes with the car. When i start the car, the idles stays at 4500rpm. I tried to adjust the idle screw, but no luck. Any help would be appreciated. thanks Quote Link to comment Share on other sites More sharing options...
rags Posted August 21, 2006 Share Posted August 21, 2006 Try removing the linkage between the carbs so that both carbs are mounted but there is nothing connecting them to each other or to the throttle linkage. Without seeing it, my guess would be that you have the linkage that's between the carbs in the wrong place, meaning that one of them is being held open. Actually, if you have a mirror, you can remove the aircleaner and pull up the piston in the carbs and look at the throttle plates with the mirror. You should be able ot see which one is being held open. Joe Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted August 21, 2006 Share Posted August 21, 2006 BTW, I like your screenname Quote Link to comment Share on other sites More sharing options...
2jzgte240z Posted August 21, 2006 Author Share Posted August 21, 2006 thanks for the help rags.. i'll check on it when i get home from work thanks z-gad. i've been following yours and cyrus post for awhile. You guys have been a big help. i've also seen you post on supraforums as well. nice car! Quote Link to comment Share on other sites More sharing options...
2jzgte240z Posted August 23, 2006 Author Share Posted August 23, 2006 both throttles are closed...i lifted each piston and both the throttle are closed..are there other suggestions?...thanks for the help Quote Link to comment Share on other sites More sharing options...
alexideways Posted August 23, 2006 Share Posted August 23, 2006 Did you check if the idle screw makes anything move, maybe you have a broken part in there, juat an idea that whent trough my mind, I don't know mutch about carbs exept that the make a hell of a nice sound and they use to make my little Rabbit go very fast in a very short time. Quote Link to comment Share on other sites More sharing options...
2jzgte240z Posted August 23, 2006 Author Share Posted August 23, 2006 messed with the idle screw alittle bit. It does help it alittle bit, but it won't get it to go under 4500rpm. i'll try to take it apart again and see what is wrong..thanks Quote Link to comment Share on other sites More sharing options...
rags Posted August 23, 2006 Share Posted August 23, 2006 I'd still take the linkage off so it's out of the equation. Since it didn't do this with the old carbs, it has to be related to them. Either the throttle plates are open or their is a vacuum leak somewhere with the carbs very rich. Joe Quote Link to comment Share on other sites More sharing options...
2jzgte240z Posted August 23, 2006 Author Share Posted August 23, 2006 Quote I'd still take the linkage off so it's out of the equation. Since it didn't do this with the old carbs' date=' it has to be related to them. Either the throttle plates are open or their is a vacuum leak somewhere with the carbs very rich. Joe[/quote'] hey joe, would it help if i took several pictures of the installation. I believe i did everything correct. im sorry, im a FI kind of guy. This carb this is fairly odd to me. thanks for the help Quote Link to comment Share on other sites More sharing options...
rags Posted August 23, 2006 Share Posted August 23, 2006 Sure, pictures are always a good thing! Quote Link to comment Share on other sites More sharing options...
