Eastwood Wrinkle Paint
getZ
I also remember having better results when the air temps where hotter. It wouldnt wrinkle if it was very cold outside.
But at anyrate, i will say that the wrinkle black powder coat eastwood sells works great. I use the stuff whenever i can. Works best to hotcoat the parts out of the oven and you can watch it wrinkle.
I have used VHT brand (spray can) with very good results.
As with any "paint" project the surface prep is most important.
The best results I have had is to sand (or beed) blast the part and then use clean varsol.
I have not tried it yet but Acetone should also work well.
Let the part air dry in direct sun for a couple hours and then spray on the coatings.
I usually go with 3 or 4 coating within like 3 to 5 minutes of each other.
I guess I just give it try and see what I get. It's only for a couple of small parts, the trim around the map light (that I will make out of aluminum) and a face plate that goes around my vintage air control panel.
Heat shouldn't be a problem. I don't think we will see a high under 100 degrees until next month.
