DarrellBuddy321 Posted August 27, 2006 Share Posted August 27, 2006 Anyone know where i can get an overhaul kit for the 87 300zx lsd? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 27, 2006 Share Posted August 27, 2006 There is no kit to rebuild the LSD. The clutches are NLA. You can shim the diff tighter if you want more lockup: http://forums.hybridz.org/showthread.php?t=92629 If you just want to replace the bearings, that should be doable. I think they're all still available except the front pinion bearing, which is a ball bearing at the end of the pinion shaft. It is also NLA according to a recent post. Quote Link to comment Share on other sites More sharing options...
Phantom Posted August 28, 2006 Share Posted August 28, 2006 Contact Standard Transmission and Gear in Fort Worth, TX. They can get you what you need or you can send them the differential and they'll do it for you. Quote Link to comment Share on other sites More sharing options...
