slownrusty Posted September 16, 2006 Share Posted September 16, 2006 Gang - Got the BMW TB mounted and the linkage working properly! Took some time and effort but here is the dilema before, how to connect A to B: Solution, no binding and lots of clearance (no chance of catching on anything): Making progress - all be VERY slow! Yasin Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 16, 2006 Share Posted September 16, 2006 Funny you posted pics about this I was wondering about it the other day. Looking good. BTW, are you going to polish the manifold? That would look sweet! Quote Link to comment Share on other sites More sharing options...
b__sosick Posted September 17, 2006 Share Posted September 17, 2006 dyno results gogogo Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 17, 2006 Share Posted September 17, 2006 Looking good, is your car a turbo or stroker or just stock? Ive heard that the 240sx Tb doesnt help at all, it just seams like it cause you have more throttle at the same throttle position as before, is yours different? Not meaning to rain on your parade. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 17, 2006 Share Posted September 17, 2006 Looking good, is your car a turbo or stroker or just stock? Ive heard that the 240sx Tb doesnt help at all, it just seams like it cause you have more throttle at the same throttle position as before, is yours different? Not meaning to rain on your parade. Do a search for his name and you'll find lots of good info about his new combo. About the TB, it all depends on your set up. You can't make that a statement about all combinations. It depends on if your vehicle could use more air or not. Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 17, 2006 Share Posted September 17, 2006 I meant for stock setups (misunderstanding) I dont think it works, but I bet it helps alot when you need more air. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted September 17, 2006 Author Share Posted September 17, 2006 Cody - Thanks - its coming along...just not at break neck speed. I might polish it or may play with different paints...we'll see!! sosick - Dyno time hopefully in about 4-5weeks Mopar - Does this help on my set-up? And yes I will use every cubic inch of airthat I can ram down my engine's throat! Yasin Quote Link to comment Share on other sites More sharing options...
veritech-z Posted September 18, 2006 Share Posted September 18, 2006 Yasin, and particular reason you opted for the bimmer unit and not the Q45? Did you just want to keep the mechanical linkage and old style TPS? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted September 19, 2006 Author Share Posted September 19, 2006 The Q45 is freaking monster its 90mm in diameter? I actually had one and sold it. The TPS is no biggie to set on it (standard three prong plug) on it but adapting the linkage would take some messing for sure and trying to adapt it plus I seem to remember that JeffP is putting down what close to 450whp and 500ft.lbs with a the 60mm KA TB, so I figure the almost 70mm BMW TB should be plenty good for me! Never say never maybe down the road if I get bored I might try it! Yasin Quote Link to comment Share on other sites More sharing options...
veritech-z Posted September 19, 2006 Share Posted September 19, 2006 I've got one in my closet, but I don't have a manifold to make it work on yet... Quote Link to comment Share on other sites More sharing options...
jbk240z Posted September 21, 2006 Share Posted September 21, 2006 I'm glad you got the linkage worked out. When you get the Z running, it should do very well. Good luck. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted September 21, 2006 Author Share Posted September 21, 2006 I'm glad you got the linkage worked out. When you get the Z running, it should do very well. Good luck. Many thanks!! Hope to have it running in about a month or so! X-fingers. Quote Link to comment Share on other sites More sharing options...
