280zx rear end swap
???? What rear did the 240SX come with? r200 viscous? I didn't know it came out as a subframe unit, probably narrow too... Hmmmm..
Regards,
Lone
It's not too narrow. I've got a '92 SX, and width is not a problem. An R200 comes in it, and from what I understand from the 240SX.org site, it is the same "short" case that the 300ZX/J30/ cases have. But only the superhicas and ABS options have the VLSD, which I have not been able to find even after several years of looking. Also, it comes with a 4.10 ratio, which for me, is a little low, even with an OD.
Terry
all ZX are R2 diffs.
only turbo cars are CV shaft.
all ZX are rear disk.
it wont be worth the effort to try to fit in to early Z..
convert the rears to disk and forget the rest- the CV can be done ala Scotty type adapters or it will bolt in with a combo of parts- do a search for this
quote:
Terry
Thanks Terry... Darn, I was getting pretty excited for a moment.... Agreed, 4.10 isn't the direction I'm wanting to go... icon_smile.gif
I'm still looking at the Tbird/Mustang IRS because of the gears and availability and price but the search goes on, I have plenty of time anyway, this is a future endeavor... icon_wink.gif
Regards,
Lone
Mike said the ZX TURBO rearends would be R200, cv, and rear disk, What's wrong with that? can it be swaped as a complete unit, with a few mounting changes for an early Z? Would it be worth it? thanks then agian how bout the 300zx !!!!!!! anything thing better about it ?
[ July 13, 2001: Message edited by: staledale ]
Thanks for the picture and info on the Cv's Scottie! Appreciate it. Yeah, if the ratio's are already in it, not a problem. I can get the whole unit like pictured for about 450.00, with Raxels CV's thats getting to be just about a grand (which is already expensive, but doable at some point), but if I had to add R and P and setup then yeah I totally agree, its getting way too expensive. 2.73 is way to numerically low for me as well, 3.08 or so would be better. I'll let you know if I find anything else suitable, I'm thinking theres a solution out there just waiting to be discovered.. icon_smile.gif
Thanks,
Lone
Lone,
the Ford 8.8 IRS is still an option for me. However, I spoke with Marty (sp?) at Raxles and he sells new HD 1.5" CVs for them at $500/pr! What I do not have is a list showing what vehicles came with what ratio. I know most of the T-Birds had a 2.73:1 and that is too tall. I know we can get these for a resonable price but if you have to cough up $500 for CVs, then also have to get a R&P and have it setup, it could get pricey.
Keep us informed on whatever you find out. Here is another good pic of that complete unit.
Now, I may be wrong, (usually have been on here), but if one was to be going with a T56 tranny, wouldn't a 4.10 axle be PERFECT? get a great launch, but then hit that .5:1 6th gear and loaf along, right? Or am I dreaming?
Depends on your motor IMHO. If it can rev to 6K or 6.5K it would help in first gear (mine is pretty much done by 5k). Otherwise the T56's first gear feels pretty short to me and thats with a 3.54 rear end, a 4.11 would wind out pretty darn quick. I can start easily in second right now with 15 inch tires in a 55 series profile. I think it was geared that way to get the fat f bodies rolling, not a problem with the Z though... icon_smile.gif
Regards,
Lone
Scottie - R&P setup shoudl be no more than $150 tops. That's what all of th eshops here charge all day long on th e8.8. As for gears - I can get you a set of 3.08 pretty easily I think and a 3.27 wouldn't be too bad either I'm thinking. 3.27 is just a little harder to find is all... icon_wink.gif
