Need help with a shimmy
Between 30 and 50 steering wheel shakes big-time. Seems to smooth out as you accel. Wheels and tires ARE balanced.
Front bushings? Alignment? All of the above?
whatzup?
tom
Hey, if you can turn the rotors yourself, watch the hub to see it it un true when it spins. Have yu hit a curb or +3" object? My 79' 280zx had the same problem.
Like Z-Gad said, check the tires for wear, if the wear is feathered of un even you got an alignment problem.
Nic
I had some money to waste one day after having some tires ballanced. Still had a shimmy at a particular speed range. Took the car immediately to the speed shop (he calibrates the machine each and every ballance job, but is a bit more expensive) and found the wheel/tire assemblies were indeed NOT ballanced. The shimmy dissappeared after he ballanced them. This happens more often than I care to mention, and especially so when I get the "Life time" ballancing.
Thanks for the replys. After a closer inspection, the tires on this car have been sitting for over 2 years and are dry rotted BAD. Its weird because all the tread is there but the side walls are dry and cracked. I went ahead and bought the car and on the way home today I put the proper pressure in the front tires and that took most of it away. I'm looking for some stock 15' turbo wheels to put on it. I just can't see buying anymore 14's and I dont 't want to spend too much money icon_wink.gif .....on wheels and tires, but I will need tires to get the car inspected.
