Crankshaft / Woodruff Key damage
2003z
Darn, just started initial reassembly and noticed this on my crank today. I'm thinking either having the machine shop fix it, or buying a used crank from the local z car wrecking yard, as I need to get everything in and running by next friday (9 days). I'm pretty sure I can't just ignore it.
Yeah, you can't ignore that, Cast cranks don't weld good IMO, so I'd ditch the crank and get another.
IMO you can't just throw in a used crank either. The journals will have to be mic'ed and the bearing clearances will have to be checked. I'd resize the rods for optimum crush and turn the crank too.
Guest beandip
Contact Kim Blough at IDAHO Z CAR . 208 466 0004 He has the solution and it is a inexpensive fix . Best of luck . Gary
Sometimes I'ts just cheaper to buy a whole motor from a wrecking yard.
If I'ts nothin special.
I know around here if you go on the right day they're 1/2 price. At some yards that means around $150.00 and then you can avoid all the machine work.
Just hone the bores and replace the rings and bearings, and you're good to go.
Just a thought.
thanks Gary, I'm going to go with his solution.
Its Loctite 660 to repair and 'glue' the keyway in. Its an anaerobic sealer that was designed specifically for this problem.
http://www.mx5.net/garage/hsue/LoctiteCrank1.html
I've had one welded before, I bought a car from some guy who's mother said it didn't run. towed it home and cranked it to see what was wrong and it did run, for 10 minutes. When the guy put the engine together he had one bearing in backwards so the rod got no oil and welded itself to the crank. How he knew, I don't know. Anyway, they welded, grinded and polished it to like new. Unfortunately, my local machine shop doesn't do that work and I really want to get the engine back together by the end of next week for a track event 11/4 and 5 at Rockingham. If it doesn't hold, the worse that can happen is underdriving my water pump and alternator and I start all over. The guy told me the stuff, once it sets doesn't come off except with a hammer and chisel, and even then its not easy.
