RB26DETT Mounts for a Z32...
tay-fu300zxtt
depends on your welding and fabricating skills. Mine are not perfect, but not crappy either. Patience was and is the key. I just set the engine were I wanted it and then used corrugated cardboard to create mockup motormounts. Then I traced the pieces onto 3/16" mild plate steel and cut and welded them. I then painted them just before I permantly mounted the engine. I am planning to put them in Autocad and have a friend cut them on his cnc plasma cutter. But, that will be well into spring of next year.
Davi
