Weight Jack Questions
Weight jacks are used to raise one corner of the car so that corner weights can be set. On the early Z the weight jacks we normally use are threaded collars and coilovers with 2.5" springs. On circle track cars the weight jacks are a large threaded shaft that screws into the body and then the top spring perch. By turning the screw in that corner gets lifted, and by turning it out that corner gets lowered. Here is an example: http://www.secureperformanceorder.com/afcostore/getproduct.cfm?CategoryID=17&ClassID=222&SubclassID=1043&ProductID=910
