z ya Posted March 9, 2001 Share Posted March 9, 2001 OK its time to pick the cam and i think I have it narrowed down to a few.The motor specs are 355 sbc/ported and polished 291 63cc heads 1.94/1.5's/air gap intake/3310 holley 750/10.4 comp ratio.I am going with comp cams.Heres the choices: 280/480,286/490 or dual pattern 274/286 with 487/490 exhaust. The tranny is a th350 with 2300 stall.All the cams are 110 lobe sep.Its going in an 70 240.The comp guy said go with the 274 for all around perf.Its rpm band is 1800 to 6000. OK lets here it.... Quote Link to comment Share on other sites More sharing options...
Racin_Jason Posted March 10, 2001 Share Posted March 10, 2001 Well I'll tell ya I wouldn't go OVER the 274 if you want to run it to only 6000rpm. With those camel humps and the compression I might try something in the 280's but its gonna go to 7000 easy. The 268 would like that 2300 stall ALOT..anything higher is gonna be alittle mushier off the line but be alot peakier later on..but with such a light car the 268 at that compression would over power street tires REAL easy off a 2300 stall. Clear as mud?..if it were my car Id run it this was..street car? = 268 with a 3.23 or 3.54 rear would be a grunty little SOB that would haul up to 6000+////RACEcar? Id run something in the 280s..maybe even low 290s and swap to a single plane mani and 3.70s out back. The car will leave alittle softer but the 4000-7500 would be BRUTAL with your combo. My $0.02... I just noticed the humps are only 1.94's...my opinion still stands but the RACE setup would be a 'bit' less than BRUTAL..but not much [This message has been edited by Racin_Jason (edited March 09, 2001).] Quote Link to comment Share on other sites More sharing options...
DavyZ Posted March 10, 2001 Share Posted March 10, 2001 I personally like Jason's recommendation of the 274 for the street. I guess it depends on how much you drive this car and what kind of driving you'll be doing. I would say to go with the milder cam because, dude, you have no idea just how fast that sucker will be as you boil the baloneys all the way down the street. Don't make the mistake of over-camming the car. After much research, I decided on a 274 cam for my V8, because the car will be very quick, very responsive, and still manageable with respect to highway driving. That same cam in you car will produce about 375-425hp(?) I guess you must ask yourself, "how much power do I really need to have fun/be fast/hurt myself? You are already there with the "mild" cam. If you don't like it, stab in another cam; they are not all that expensive. Hope this info helps. Choose wisely. David Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 10, 2001 Share Posted March 10, 2001 I would defiantly go with the dual pattern cam. Your heads need help on the exhaust side and that is what that cam is designed to do. Quote Link to comment Share on other sites More sharing options...
pparaska Posted March 11, 2001 Share Posted March 11, 2001 ...double hump heads. The generally don't flow much more if you open the valves beyond 0.46-0.48. And the exhaust ports don't flow as well as the newer heads, so that dual pattern cam makes alot of sense. I'd go with the 274/286 for a street ride. ------------------ Pete Paraska - 73 540Z - Marathon Z Project pparaska@home.com Pete's V8 Datsun 240Z Pages Quote Link to comment Share on other sites More sharing options...
z ya Posted March 11, 2001 Author Share Posted March 11, 2001 OK , I know the 274 is sweet all around,but I plan on going to some trick flow 23 degree aluminun heads when possible.Also, if I later go to an 700r4 I figured that it would almost have TOO much bottom end and never hook up.My brain says 274 but my heart says 286... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 11, 2001 Share Posted March 11, 2001 Chevy style 23 deg. heads have a much lower exhaust to intake flow ratio than would be desirable. The dual pattern will serve you better. The exhaust side of the 274 cam is the 286/490. If you worried about the bottom end lower your stall speed. Light car, lots 'o tork, independent rear?, I doubt you'll need much. Plus if you do the 700R4 it has a 3.06 first gear, and you'll have real problems hooking that first gear. Especially if you stall the motor into it's tork band. It doesn't take much to move a 2600 lb car. I personally am thinking 276 roller dual pattern cam, single plane manifold, stock stall converter, 23 Deg TFS heads, and 200R4. Gearing plays a large roll in what your trying to do. Quote Link to comment Share on other sites More sharing options...
