zeiss150 Posted November 25, 2006 Share Posted November 25, 2006 Hey guys, I was wondering if anyone ever Jethot coated the Stock Turbo Exaust manifold and if so how much does it lower the temp under the hood? are the any other benifits to getting it coated? Like will the turbo spool up faster? does it mess with the O2 sensor? Can the cast iron take the heat? Just wondering, Matt- Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted November 26, 2006 Share Posted November 26, 2006 Their are quite a few of us L6 guys that have had their manifolds Jet Hot coated. It really depends on your total package as to what affect it will have on spool up.... On a total stock set up, I don't think you will notice much difference in spool up, but if your running a newer all ball bearing turbo, and tuned correctly, I'd bet you could feel the difference. It will, for sure, help to keep your under hood temps down. I noticed a drastic difference in radiant heat. Everything close to the turbo was even cooler... I can't see it affecting the O2 sensor... and yes, the cast iron can take the coating.... Quote Link to comment Share on other sites More sharing options...
HB280ZT Posted November 26, 2006 Share Posted November 26, 2006 I have my exhaust manifold, turbo and downpipe Jet hot coated and love them. They look good and do keep the underhood temperature down some. HB280ZT Quote Link to comment Share on other sites More sharing options...
Alex_V Posted November 26, 2006 Share Posted November 26, 2006 how much do the coatings run and did you guys just do an inner coat? Seems to be worth while upgrade to my L28et while i look for a good chassis. ~Alex Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted November 26, 2006 Share Posted November 26, 2006 Coat both inside and outside. Quote Link to comment Share on other sites More sharing options...
zeiss150 Posted November 26, 2006 Author Share Posted November 26, 2006 If you coat the inside of the turbo housing wont that mess with the clearences between the turbin blades and the housing and will that mess with performance? How much does it cost to get the manifold coated? Thanks for the replies! Matt- Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted November 29, 2006 Share Posted November 29, 2006 If you coat the inside of the turbo housing wont that mess with the clearences between the turbin blades and the housing and will that mess with performance? How much does it cost to get the manifold coated? Thanks for the replies! Matt- I too wonder about coating the inside? My turbo is in mint condition(ie. No rust) and I would like to coat it if possible to help with efficiency, and prolounge the life of it. Quote Link to comment Share on other sites More sharing options...
